Fuel Injector Help
Old Sep 7, 2011 | 09:41 PM
winrylused's Avatar
winrylused
Default Fuel Injector Help
I've read the info thread about Injectors under FI threads but im not quite understanding the difference with high and low impedence. my main goal in whp is 450-500 with GTM stage 1 TT. So far i got my block and crank just ordered the bearings but im reading on ahead so im prepared but im still not understanding if i should go high or low impedence. To my understanding the CC you want is around the range in whp you want to go to correct? Any advice or help is much appreciated.
Old Sep 8, 2011 | 09:39 PM
Nealoc187's Avatar
Nealoc187
low impedance injectors are generally very large - the type used in 700 or 800whp+ type builds generally. they require low impedance injector drivers, etc.
stock injectors and direct replacement injectors like deatschwerks are high impedence injectors.
for the power level you are looking for you are looking for you could get away with 450cc injectors if you really went wild with the fuel pressure and IDC, but a better idea would be to run something like a 550 or 600cc injector to keep IDCs and and FPs lower. You'll also need a fuel pump. deatschwerks.com can provide you with both the injectors and a fuel pump if you want to get some good parts from a good company.
Old Sep 8, 2011 | 11:33 PM
winrylused's Avatar
winrylused
Default Reply
Thanks for the tip but to verify i should be getting 550-600cc High Impedence for the range Im going?
Old Sep 9, 2011 | 06:59 AM
str8dum1's Avatar
str8dum1
There are high and low Z injectors of all sizes.
You need to get the type of injector that your EMS will drive. Thats your only concern. FCON,Cipher,UTEC, SS box,stock EMS needs high Z. Haltech, Proefi can use either.
I'd get the DW800cc injectors with a 340LPH DW pump for headroom for your setup.
