problem putting my quaife lsd into my car
Old Sep 9, 2011 | 05:54 PM
zach711f's Avatar
zach711f
Default problem putting my quaife lsd into my car
i have a problem putting my quaife lsd into my car. i have a 2003 350z and got a quiafe qdf13L from intensepower.com i needed the qdf11L but they dont care to answer my phone calls or take care of their customers even when they send out the wrong parts..so now im trying to fit these stub axles in and one side wont fit. it looks like theres a c ring in the quife already on the side with 2 gear sets. is that supposed to be there? i thought they go on the stub axle first..any ways i have a stock vlsd diff the one with one short and one long side axles..i bought to short stub axles from an open diff and still cant figure out why its not fitting togather. please help
Old Sep 9, 2011 | 08:06 PM
WTFMike's Avatar
WTFMike
I have no real input, however have you read this thread? It is a DIY quaife lsd install.https://my350z.com/forum/engine-driv...tall-pics.html
Hope it helps.
Old Sep 10, 2011 | 01:02 PM
zach711f's Avatar
zach711f
i know how to install the thing.. i just cant get the stub axles to work or if i even have the right ones. i dont know who to contact because quaife is in another country so i cant really call them up on my cell
Old Sep 24, 2011 | 02:15 AM
2.75Spear's Avatar
2.75Spear
zach711f, call: 800-959-0145, ask for Adam. He works for TH Motorsports they are a Quaife distributior in IL. Even though you didn't buy it from him, he may help you. Their shop installs the Quaife, in fact, I will probably have mine installed by them next month. Let me know how it goes, good luck.
Old Oct 18, 2011 | 08:49 AM
350z-Helsinki's Avatar
350z-Helsinki
You need to shorten the other axlestub to make it fit. Other option is to order a new shorter axlestub but those are a bit expensive.
Old Oct 18, 2011 | 09:27 AM
bbs350z's Avatar
bbs350z
id put them on blast until you get the right part. trust me its worth the wait. other than that, th motorsports is a group of good guys, so you cant go wrong with them
Old Oct 19, 2011 | 12:40 PM
makdaddynuge's Avatar
makdaddynuge
if you have a stock vlsd diff, the QDF13L is the correct differential for your application. Which I believe means you can re-use the factory stub axles from stock vlsd.
The QDF11L is for base model open diff 350z/g35
Old Oct 22, 2011 | 06:32 AM
Fluid1's Avatar
Fluid1
QDF13L - drop in for stock VLSD
QDF11L - drop in for stock open diff
OP, is your 350Z a base model?
Chris350z03
Oct 8, 2023 07:19 PM
lolwatbro
Oct 9, 2021 04:58 AM
pslamp32
Feb 8, 2017 09:07 AM
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
3vilbunny
Sep 13, 2015 12:31 PM
