Clutch pilot bearing
Old Sep 11, 2011 | 09:28 AM
AARONHL's Avatar
AARONHL
Default Clutch pilot bearing
Who sells the most durable, long lasting (BEST) pilot bearing??? Replacing my clutch soon.
Thanks,
Aaron
Old Sep 11, 2011 | 10:02 AM
hellsoldiers08's Avatar
hellsoldiers08
Your mamma
Old Sep 11, 2011 | 10:43 AM
ChuckW's Avatar
ChuckW
Nissan does.
Old Sep 11, 2011 | 10:47 AM
AARONHL's Avatar
AARONHL
Originally Posted by hellsoldiers08
Your mamma
Pretty sure she is an accountant and does not manufacture or retail pilot bearings.
Old Sep 11, 2011 | 10:49 AM
AARONHL's Avatar
AARONHL
Originally Posted by ChuckW
Nissan does.
That's what I was thinking, but do you know if anyone makes one that is better built? My transmission sounds like it has rocks in it and not looking forward to hearing the same a few thousand miles after I change the clutch.
Old Sep 11, 2011 | 10:55 AM
ChuckW's Avatar
ChuckW
I've read a million posts here and the answer to your question has been stated many times that the stock one is more than sufficient.
Just make sure you have a good match with the clutch and new, light flywheel and be ready for the added noise.
Old Sep 11, 2011 | 03:32 PM
hellsoldiers08
then your mamma knows how to search and reseach things right?? hmm this is a worthless post and could of been founded very easily... /thread.
Old Sep 11, 2011 | 03:57 PM
ChuckW's Avatar
ChuckW
We all look forward to the rest of your contributions. You sound like you were just released from prison. I hope your soreness goes away quickly.
Old Sep 11, 2011 | 05:41 PM
AARONHL's Avatar
AARONHL
Thanks, Chuck.
I'm thinking about an Exedy clutch kit and not sure if I wanna get the stock fly resurfaced or go lightweight.
Old Sep 11, 2011 | 09:50 PM
hellsoldiers08
hmm.... that the best you can say.... we in high school or something? Grow up and stop wanting every thing feed to you.
Old Sep 12, 2011 | 05:18 AM
djamps's Avatar
djamps
My JWT kit came with one... I'd say if the kit includes one use it, if not use a Nissan one. And the noise isn't the pilot bushing it's the gears themselves. Try a slightly heavier oil and don't stray from the stock dual mass if you don't want it louder. After using a single mass I eventually went back to stock dual mass.
Old Sep 12, 2011 | 06:40 AM
MR RIZK's Avatar
MR RIZK
http://uniqueautosports.com.au/
Old Sep 12, 2011 | 07:24 AM
AARONHL's Avatar
AARONHL
My slop box is getting so bad, I have to stomp on the clutch pedal for everything to engage and shift smoothly..
Old Sep 13, 2011 | 02:10 AM
Mcutali's Avatar
Mcutali
Default pilot bearing
my jwt clutch kit flywheel combo came with one too, and in 240's ive always just used a oem.
Old Sep 13, 2011 | 03:00 AM
pss350z's Avatar
pss350z
I'm finding your posts quite entertaining with all the spelling and grammar errors. I was feeling kinda sh!tty about myself.... Thanks.
Old Sep 13, 2011 | 04:00 AM
JasonZ-YA's Avatar
JasonZ-YA
http://www.importpartspro.com/ni30robepibu.html
-J
Old Sep 13, 2011 | 05:40 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the rattling you're hearing isn't your pilot bushing, it's your throw out bearing, and you're options are stock, or stock.
Old Sep 13, 2011 | 08:35 AM
AARONHL's Avatar
AARONHL
O so stock is a brass bearing? The Nismo changes to a roller style?
Old Sep 13, 2011 | 08:37 AM
AARONHL's Avatar
AARONHL
I have noises whether the clutch is pressed or not pressed. The noise does change when it's engaged or released.
And your also saying stick with the OEM throwout too?
Old Sep 13, 2011 | 09:37 AM
Z1 Performance
Former Sponsor
the pilot bushing is not going to make the car exhibit noise beyond a whine or whirring sound (as it drys, or has score marks on it, it sorta sounds like a worn skateboard wheel bearing). Rattling noises are all throw out bearing related, or indicative of deeper issues in the transmission itself, or if the car was purchased used, a sign that you may not have a stock flywheel in the car
I wont say my way is more right or less right than anyone else, but I use nothing but a stock pilot bushing on my car, and have never had any need or desire to use anything else. My throw out bearing is not a stock 350Z one, but it is a stock Nissan part from an older model (due to the clutch I use, which requires use of a different bearing and different length sleeve vs stock). There is a roller bearing design for those that want it, we offer it too.
Most of the clutch kits on the market include a throwout bearing and pilot bushing - you can use a different pilot if you want, totally up to you in terms of benefit/cost. There is no upgraded throw out bearing. Both are very simple parts and sorta either work, or don't work
