Need help selecting a clutch
Old Sep 23, 2011 | 09:20 PM
Mike Anthony's Avatar
Mike Anthony
Default Need help selecting a clutch
I did searches and whatnot before posting this and couldn't exactly find what I was looking for. There's alot of different stuff for different applications.
My clutch in my stock 07 HR daily driver is starting to slip so I would like to replace it. I'm not exactly sure what clutch would be the best to replace it with. I see the JWT clutch/flywheel combo is very popular. I also read that the slave cylinder? should be upgraded aswell as it doesn't work well with aftermarket clutches. What all should I replace when I get this done? When I press the clutch pedal in and out I feel a very slight grinding feeling. Is there a bearing I should replace?
Sorry I don't have much experience or knowledge with clutches, that's why I need some help! Thanks
Old Sep 23, 2011 | 11:18 PM
Mcutali's Avatar
Mcutali
Default jwt
i own the jim wolf, for 4 years amazing, no issues, stock slave... stainless agency power clutch line. 700 for the clutch and flywheel. people complain that it chatters, get over it. its the 350z sound youll come to know.
Old Sep 23, 2011 | 11:48 PM
Frosty87's Avatar
Frosty87
If you have an hr get the upgraded slave cylinder if you don't and get something with a heavier pressure plate you'll rip the bearing out ..
Old Sep 24, 2011 | 06:22 AM
BipJip's Avatar
BipJip
I got a 07 ZR, i purchased a southbend stage 2, with single mass lightened flywheel (23#) and a upgraded CSC (with stainless lines). it has the feel of a stock clutch but is way better in driveablitiy. i got the whole set up from cuztompartz. their the only ones with an upgraded CSC.
Old Sep 24, 2011 | 06:25 AM
vtchang's Avatar
vtchang
Nice meeting you yesterday and enjoy the intakes.
You have two options.
1) Get OEM clutch and CSC
2) Get a HD CSC and pick from any of the billion aftermarket clutches on the market.
While you change out your clutch, you may also want to consider getting a new flywheel, pilot bearing, ss line, and rear main seal depending on the # of miles on your car.
The HD CSC is a more popular choice because it will enable you to use any clutch kit of any Z33 model year.* There is a thread in the VQ35HR subforum. You should give it a quick read. Some HR clutches were not designed properly (ie. HR JWT) and have caused the OEM CSC to fail.
JWT is certainly a more popular choice due to its stock like feel and price ($775 from IPP the last I checked).
It ultimately boils down to what you plan on doing with your car and how much money you are willing to spend. You can spend $800 on JWT and be done with it or spend 1.8k on a OS Giken Grand Sport Touring. Don't forget about used clutches in the marketplace too. There is also a Carbonetics twin disc in the marketplace going for a reasonable price.
Since you are local, I suggest you call Hill's Garage in Balitmore and speak with Frank. He'll be able to help you out better than anybody else.
* may want to double check with customerpartz
GL
Old Sep 24, 2011 | 06:55 AM
vtchang's Avatar
vtchang
I got exactly what you got... 07 ZR w/ southbend stage 2, single mass flywheel, and HD CSC.
Funny.
Old Sep 24, 2011 | 08:39 AM
Mike Anthony
GL
You too. I'm gonna put the intakes on probably next weekend. Lookin' forward to it. Thanks
That twin disc clutch... Someone told me that twin disc clutches aren't really recommended for daily drivers.
I just want a solid setup with something that is going to work. Just broke 40k miles and this clutch is pissing me off.
Old Sep 24, 2011 | 06:52 PM
You will have to determine if it is the clutch or slave. Slave problems are generally peddle related: peddle gets stuck and will not return. Slip is clutch related: the friction surface will not hold the flywheel.
Proper diagnosis is essential. You do not want to replace one item when the other is at fault.
Old Sep 24, 2011 | 08:25 PM
Mike Anthony
It only feels like it's "slipping" when beginning to move. It kinda catches then releases then catches then releases, besides that it doesn't have any other slipping issues that I've really noticed. The pedal stuck to ground on me once, but came back up and I haven't had that problem since. The things that is concerning me most I believe is the clutch pedal seems to pulse it self most of the time. If you put your foot on it and hold it about where it catches (without it in gear) and all the way to the floor, it has a slight pulse to it. I have no idea what that problem could be. I've driven plenty of manuals before and have never felt that. Besides those issues, the pedal also feels like its grinding slightly when I press/depress it, like its a bearing or rubbing against something metal.
Old Sep 25, 2011 | 07:22 AM
BipJip's Avatar
BipJip
Funny.
its a nice setup, and gets rid of some of the issues with the stock clutch.
Old Sep 25, 2011 | 07:38 AM
Mike Anthony
What is ZR? Will that setup work on my HR?
Old Sep 26, 2011 | 04:01 AM
BipJip's Avatar
BipJip
the ZR is the convertable version of the Z. i have the VQ35HR motor also. and this setup will work nice for you but you have to get the upgraded Concentric Slave Cylinder or you'll have nothing but problems after a while. the stock one doesnt have the power to handle a better than stock clutch.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
