350z Differential Weight
Old Sep 30, 2011 | 12:22 PM
MouseTrap's Avatar
MouseTrap
Default 350z Differential Weight
My Mickey Thompsons ate up my differential bushing and its coming out tomorrow for the SPL Solid kit. Install looks straight forward but I had a couple of differential questions..
How heavy should I expect the differential to be? Cant find much information about it and I want to be prepared for it to come down.
And in terms of the subframe differential bushing coming out will I need to jack the car up or will ramps be sufficient? I dont see the need to remove the wheels if I dont have to.
If you guys are nice Ill do a nice install thread
Old Sep 30, 2011 | 12:26 PM
RandomHer0's Avatar
RandomHer0
I've done both those installs, I have DIY threads somewhere...
Anyways, its pretty ****en heavy, I did it alone, dropped it on my chest and rolled it off. To put it in, I used a jack I think...
I don't see why you couldn't use ramps as long as you get the height you need.
Old Sep 30, 2011 | 12:28 PM
RandomHer0's Avatar
RandomHer0
https://my350z.com/forum/engine-driv...e-install.html
Old Sep 30, 2011 | 03:39 PM
bbs350z's Avatar
bbs350z
^ i did the above mentioned, and also used my knee to help brace it on the reinstall. that diff pwnd me
Old Sep 30, 2011 | 03:42 PM
AngelsVQ's Avatar
AngelsVQ
i was able to lower the diff onto my chest and drag out from under the car with it on my chest. just make sure it does not fall on you, as it is heavy enough to break you ha
Old Sep 30, 2011 | 04:45 PM
MouseTrap's Avatar
MouseTrap
Thanks for the quick response guys!
Ill probably use some combination of a friend, jack, skateboard to move it around.
And for the thread, I cant believe I havent found that one already... Its like it was filtered haha but thanks a ton that will make it go a bit quicker. Post a pic or two after install tomorrow morning
Old Sep 30, 2011 | 04:52 PM
MouseTrap's Avatar
MouseTrap
Ew you got the cool blue ones I wanted the cool blue ones but they sent me black
I have a Daytona Blue haha
Old Oct 1, 2011 | 05:12 AM
RandomHer0's Avatar
RandomHer0
I dont think they make them in blue anymore.
Im old school :P
Old Oct 1, 2011 | 05:57 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
about 85 lbs
Old Oct 1, 2011 | 09:03 AM
MouseTrap's Avatar
MouseTrap
Originally Posted by Z1 Performance
about 85 lbs
+1
Im about halfway through right now, just got my laptop cuz the girlfriend took her phone and pandora to lunch 3 bloody knuckles so far though
Old Oct 1, 2011 | 12:40 PM
RandomHer0's Avatar
RandomHer0
Well done man, keep at'er
Old Jul 16, 2012 | 03:25 PM
MouseTrap's Avatar
MouseTrap
Revived from the dead.
SPL bushings update
Runnin great. Finished the install myself after all haha. I wish I had a picture of the contraption I had to make. I got a bearing press from Autozone, a couple of THICK aluminum plates, and a 4 inch diameter aluminum sleeve. Using the metal washers from the lobes in the front, which for some awesome reason are the same size, I pressed it out pretty fast. Cutting the rubber out first definitely helped though. Probably have 15k on them now and they are great. Held up with the slicks too.
Old Jul 17, 2012 | 09:55 AM
djamps's Avatar
djamps
SPL bushings update
Quick question while you're here. When you had it all back together did the front pushings sit perfectly flat against the subframe? Mine aren't quite flat ... I have a feeling my rear diff bolt is bent from my previous blowout throwing everything off...
Old Jul 25, 2012 | 11:44 AM
F2CMaDMaXX's Avatar
F2CMaDMaXX
I'm not sure it necessarily is straight at that point, did you re-use the oem top hats and rubber washers on the ears at all?
On the solid front bushings, are they two piece or just one solid block all through the ears?
And yes, the diff is, 'prepare yourself to lift' heavy, was not expecting that. Use a trolly jack to lower it down and offer it up. Helps to have a friend as there is some juggling around to get it down past the exhaust/driveshaft etc.
Old Jul 25, 2012 | 06:14 PM
laurelhallman's Avatar
laurelhallman
issyz
Jul 2, 2017 03:04 PM
Justin100
Nov 29, 2015 03:58 PM
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
codek
Sep 28, 2015 03:03 AM
