Upgrading My injectors
Old Oct 1, 2011 | 07:44 AM
Juni0r's Avatar
Juni0r
Default Upgrading My injectors
I'm thinking about getting some 650cc injectors and getting a fuel rail for it. It seems a little to easy to install and even the buy. Is there any other parts I'm missing or need to upgrade as well?
Old Oct 1, 2011 | 07:53 AM
suprasam's Avatar
suprasam
are you doing anything else to warrant the need for more fuel?
Old Oct 1, 2011 | 09:31 AM
DaveJackson's Avatar
DaveJackson
Master
I think this is a bad idea unless you are running FI. The stock EMS will likely have a tough time with bigger injectors and even if it doesn't, I don't think there is any gains to be had.
The only "upgrade" would be to stick with the same size and buy an aftermarket name brand that you think will be better than the OEM.
Old Oct 1, 2011 | 02:57 PM
superchargedg's Avatar
superchargedg
Damn Noobs
All i want to know is why?
Old Oct 1, 2011 | 02:58 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
asssuming you have an engine that needs 650cc injectors you'll need
fuel pump
return fuel kit
ecu/retune
Old Oct 1, 2011 | 09:58 PM
Juni0r's Avatar
Juni0r
yea well I'm planning on going FI this coming january, but stil undecided. I currently have nismo headers, nismo CAI, Unorthodox pulley kit. I mean for right now what I really want is to gain as much HP as I can before going FI.
Old Oct 2, 2011 | 02:50 AM
suprasam's Avatar
suprasam
I would wait until you are sure you are going FI. No need to waste the time and money for minimal gains.
Old Oct 2, 2011 | 05:56 AM
DavesZ#3's Avatar
DavesZ#3
At WOT an NA Z runs pig rich. IOW - more than enough fuel is available for the amount of air you can get through the system. If you want to get as much HP as you can without going FI, get a tune after you do all the NA mods.
Old Oct 2, 2011 | 06:52 AM
Juni0r's Avatar
Juni0r
Yea, I guess I will wait. Hou about hitting u enging internals such as cams, pistons, valves?
Old Oct 2, 2011 | 06:57 AM
djamps's Avatar
djamps
If going F/I, definitely get valves they are pretty much mandatory. Pistons and cams are optional.
Old Oct 2, 2011 | 08:02 AM
Cass007's Avatar
Cass007
What?
WHAT??
Old Oct 2, 2011 | 09:06 AM
Ruthless18x's Avatar
Ruthless18x
Get nitrous.
Old Oct 2, 2011 | 09:21 AM
e30cabrio's Avatar
e30cabrio
Get an F-16.
Old Oct 2, 2011 | 01:25 PM
Z1 Performance
Former Sponsor
the short answer: it depends
the long answer: on your budget, your goals, your skill level of building/owning a car that will be that significantly modded. If you're going this route, the first thing you need is a daily driver
