The Death of a Built VQ35TT.....in pics
Old Oct 26, 2011 | 08:36 AM
Fluid1's Avatar
Fluid1
Default The Death of a Built VQ35TT.....in pics
Out with the old, in with the new.
Is that metal in the oil pan? Yup
Lonely giant intercooler setup
Upskirt shot, wide intercooler
The block's ok! Studs too
mmmm....oily head(s)
Da Krank
Pistons, rods, cams, etc
The twins, shortly before they are sent for reconditioning:
And thus begins my LQ9 / T56 / Sikky build.
Old Oct 26, 2011 | 08:40 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Spun a bearing? Oil starvation?
Old Oct 26, 2011 | 08:44 AM
Fluid1's Avatar
Fluid1
It was a combination of things, a couple bearings spun for sure, and I was adding a quart of oil a day during the last week. Unfortunately the shop couldn't get the car in when they were supposed to, and more damage was done in the days beetween then and when I actually was able to get the car to the shop.
Old Oct 26, 2011 | 08:45 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I see, good luck with your future plans!
Old Oct 26, 2011 | 08:46 AM
Fluid1's Avatar
Fluid1
Thanks brother. I'll be sharing step by step
Old Oct 26, 2011 | 08:49 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Why are you reconditioning the snails?
To sell the TT kit or are you planning on trying to use them?
Old Oct 26, 2011 | 09:45 AM
str8dum1's Avatar
str8dum1
do you have your oil anaylsis's from your previous oil changes that may have suggested a problem was forming?
Old Oct 26, 2011 | 01:03 PM
Fluid1's Avatar
Fluid1
Correct- to sell the kit. I will likely use a Precision Turbo .76 bb on the LQ setup.
Nope. I deserved what I got. Monitoring will therefore be a large focus on the new build and maintenance.
Old Oct 26, 2011 | 01:18 PM
ch1215g's Avatar
ch1215g
pics dont work =/
Old Oct 26, 2011 | 01:46 PM
Bmurray350z's Avatar
Bmurray350z
That sucks. On the bright side your moving on to bigger and better things!
Old Oct 26, 2011 | 01:49 PM
bbs350z's Avatar
bbs350z
+1 welcome to the dark side!
Old Oct 26, 2011 | 02:19 PM
CTZ860's Avatar
CTZ860
Uggg that stinks man. Sorry to hear but can't wait to see the new setup.
A side note (newb *** question) When you guys say spun a bearing, which bearing/bearings are you referring to and what would cause this?
Old Oct 26, 2011 | 02:31 PM
qqqqball's Avatar
qqqqball
Usually a rod bearing if you spun would cause low oil pressure; but to burn a quart every day and be all over the place like that would have to be a bad rear or front main seal; maybe a improper line hone; or it could be bad rings i.e. someone lined all the gaps up in a row i have seen that many times causing oil starvation. but this looks like a couple of things, also looks like the bearing were put in dirty on the crank lots of scoring
Old Nov 1, 2011 | 05:51 AM
binder's Avatar
binder
sucks your car died but i'm curious why you kept driving it if it had a problem? I would have just parked it and waited for the shop to be free.
Old Nov 1, 2011 | 05:18 PM
Fluid1's Avatar
Fluid1
To be more detailed: The same shop was supposed to be finished with my other car, G37, on Saturday. My Z was supposed to go in Saturday. 'Nothing' seemed wrong at that point. Well, I got a call at 6pm Friday saying my G would not be done until Tuesday. Tuesday, on the way to the shop, I heard the noise for the first time.
Old Nov 1, 2011 | 09:20 PM
binder's Avatar
binder
oic, well that sounds different than what i thought with the first description. either way still sucks
Old Nov 1, 2011 | 09:35 PM
midz350's Avatar
midz350
I can only imagine how many broken VQ's around the world.
GL OP.
Old Nov 1, 2011 | 11:11 PM
ronn1's Avatar
ronn1
"I have a 740rwhp 2003 base Z. Please PM me options for my power level.
Thank you
Old Nov 2, 2011 | 04:43 AM
taywan's Avatar
taywan
wow, sucks man...i may not be too far behind u on tearing up mine..gl w/ the other...
Old Nov 2, 2011 | 05:42 AM
Fluid1's Avatar
Fluid1
Thank you
Basically.
This is why I'm going with a LQ9 fully built, boosting about 800-900 rwhp daily.
Thanks, midz350
