Cusco RS making a lot of noise when turning
Old Dec 13, 2011 | 06:15 AM
Ted J's Avatar
Ted J
Default Cusco RS making a lot of noise when turning
Hey Guys,
I have a Cusco RS that is making a good amount of noise when turning in a parking lot with just a slight amount of power being put onto it.
I thought maybe it was set to a higher lockup percentage since I bought the pumpkin used and have no idea what it is set too. I have taken it apart and have learned it is set to 1.5 way and 60% lockup. So it's not the lockup that is causing this.
I'm also using Motul 90 PA fluid which I hear is suppose to work pretty good. I was thinking of maybe changing the order of the clutch plates (keeping the pattern the same for the 60% lockup) but swapping out the clutch plates so there would be some new mating surfaces. For example if this was how it was:
1 2 (3 4) (5 6) (7 8) 9 10
and plates in ( ) are the ones in pairs stacked beside each other I'd have them swap places to give a new surface of the clutch disc exposure to friction and have it go like this:
1 2 (4 3) (6 5) (8 7) 9 10
I've also thought of just trying regular oil for the rear end and getting some of that positrax's stuff from Autozone for I've used that in the past and had good luck but dunno.
Thanks!
Old Dec 13, 2011 | 07:08 AM
VQ35deMax's Avatar
VQ35deMax
Sounds like a normal noise from a clutch type lsd.
Old Dec 13, 2011 | 07:55 AM
Kwame's Avatar
Kwame
Old Dec 13, 2011 | 08:23 AM
Ted J's Avatar
Ted J
I know what you mean but the Cusco RS is suppose to be quieter for it's got springs for it's pre-load and when set to 60% lockup I've read that it quiets it down a lot so I dunno.
Old Dec 13, 2011 | 08:30 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Yep, unless the noise suddenly got worse I wouldn't worry about it.
Old Dec 13, 2011 | 08:41 AM
03threefiftyz's Avatar
03threefiftyz
Mine is quite loud, but it has seemed to quite down slightly after each fluid change...it is at 80% lock-up, though.
Old Dec 13, 2011 | 09:01 AM
Ted J's Avatar
Ted J
Cool, will do, ty for the info!
Ted J's Avatar
Ted J
What fluid and/or friction modifer you using?
Old Dec 13, 2011 | 09:02 AM
03threefiftyz
Motul 90
Old Dec 13, 2011 | 09:44 AM
Ted J's Avatar
Ted J
Motul 90
Cool, ty!
Old Dec 13, 2011 | 10:52 AM
RandomHer0's Avatar
RandomHer0
Exact same thing for me, fresh Motul 90 at the beginning of the season, by the end shes clackin around pretty good. Thats how I know its time for new fluid.
Old Dec 13, 2011 | 10:58 AM
2TH PWR's Avatar
2TH PWR
mmm can't wait for massive amounts of noise!
it's like a fresh shot of testosterone and awesomeness .
Old Dec 13, 2011 | 10:59 AM
RandomHer0's Avatar
RandomHer0
People look at me like my car is broken.
Shes a beast on track though lol
Old Dec 13, 2011 | 12:14 PM
Ted J's Avatar
Ted J
Oh snap, had less than 500 miles on the first Motul 90 fluid before pulling out the rear to check what percentage of lockup it had in it.
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
dcains
Nov 11, 2015 11:36 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
seagrasser
Oct 11, 2015 03:27 PM
