Jwt vq35 adjustable exhaust cam gears.
Old Dec 22, 2011 | 08:41 AM
midz350's Avatar
midz350
Default Jwt vq35 adjustable exhaust cam gears.
JWT just released this:
JWT has just added this set of adjustable VQ exh. cam gears for engine builders intent on gaining the most out of a VQ35 or VQ40 engine, turbo or NA. With eight positions of 2.5 crank degrees each, these gears allow enough adjustment to span a full tooth if needed for infinite cam timing corrections. The gears open up many possibilities like converting Revup engines to run in DE configuration, resetting exhaust cams after altering crank sprocket timing, and just being able to easily explore all cam timing options. Part# AVQ35-EGEAR
Old Dec 27, 2011 | 03:39 AM
MR RIZK's Avatar
MR RIZK
Nice.. However removing the front timing cover multiple times while the engine is in the car is not a fun task just to "test"
Old Dec 28, 2011 | 08:09 AM
Kwame's Avatar
Kwame
EXACTLY... therefore as cool as this is, I'll pass.
Old Jan 3, 2012 | 04:01 PM
kacz07's Avatar
kacz07
I just saw these a few days ago. I have to take apart my crap to replace the exhaust vtc sprocket, so I might upgrade to Nismo VTC sprockets(2) and these, if a convo w JWT proves fruitful.
Old Jan 28, 2012 | 05:01 PM
rich2342's Avatar
rich2342
What do these do exactly? What is the benefit? Is it for built applications only?
Old Feb 2, 2012 | 06:16 PM
johnwigs's Avatar
johnwigs
why would you take the timing cover off? the whole point of adjustable cam gears is that when you "degree" cams is to change your lobe center seperation... you should already know what timing is needed prior to assembly the engine for the final time
exhaust VTC sprocket? what is that? this is for DE and 4.0 engines... could be used on VHRs if you were doing an exhaust cam...
2006 Rev-ups use an exhaust retarder there is no parts that go bad in the timing cover, maybe the clutch material that is in the VTC covers...
sales@czp
Sep 23, 2019 03:30 PM
Li1ag
Sep 28, 2015 02:07 PM
