Can the valve covers be powder coated?
Old Jan 9, 2012 | 06:30 PM
bikinilust's Avatar
bikinilust
Default Can the valve covers be powder coated?
Does anyone know if the valve covers can be powder coated?
If you happen to have your valve covers done, can you please supply the companies name?
Or would you guys happen to know at what temperature they baked the covers at?
Old Jan 9, 2012 | 07:51 PM
Italianjoe1's Avatar
Italianjoe1
Problem ususally with baking plastic covers is melting the baffles inside of them. I know we've had that issue in the Cobalt world with the aluminum covers, they coat just fine but it melts the PCV baffling and sometimes restricts the flow.
Old Jan 9, 2012 | 08:51 PM
bmccann101's Avatar
bmccann101
them ovens get REAL hot...id assume the answer is no.
Old Jan 9, 2012 | 10:02 PM
bikinilust's Avatar
bikinilust
I remember someone saying they had their valve covers powder coated wrinkle red in 3 stage.
I think it may have been the owner of this engine that said that
Old Jan 10, 2012 | 04:56 PM
saywat?'s Avatar
saywat?
would suck if u have to replace the covers if it leaks and repaint it again lol
Old Jan 10, 2012 | 05:00 PM
ZS14RR's Avatar
ZS14RR
Yes they can. Powder coating is very durable
Old Jan 10, 2012 | 10:33 PM
bikinilust's Avatar
bikinilust
Ok.
Do you know who can coat them?
or at what temperature they can be coated at?
Old Jan 11, 2012 | 05:14 AM
ZS14RR's Avatar
ZS14RR
Originally Posted by bikinilust
Ok.
well i am in MD so no help..
but powdercoating is very straight forward you can probably do it yourself and save a crap load of money.
coating is at regular temp. you have to bake the item after its been coated in a oven.
eastwood makes a great started kit.
Old Jan 11, 2012 | 12:27 PM
Cass007's Avatar
Cass007
It can be done, I've had mine done and it was MUCH better than the painted set I had.
My guy baked at a slightly lower temp, but the coater should have their own process. If they know enough to know how to get the plastic covers to hold a charge so the powder sticks, they should be able to know what temp to bake at.
Old Jan 11, 2012 | 12:36 PM
bikinilust's Avatar
bikinilust
We do our own powdercoating.
But id rather try to gather information prior to experimenting with covers
Differentt plastics can take different amounts of heat prior to deforming
Some plastics need to be degassed prior to coating
Old Apr 3, 2012 | 01:37 PM
tvan's Avatar
tvan
it can be done, leave it to the professionals...
Old Apr 3, 2012 | 03:21 PM
BoomerZ33's Avatar
BoomerZ33
definitely! look into ceramic thermal barrier coating as well.
Old Apr 3, 2012 | 05:28 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
Wow that's insane
Old Apr 3, 2012 | 09:53 PM
bikinilust's Avatar
bikinilust
Finally got around to powder coating a valve cover.
Luckily/unluckily we had a broken valve cover in the shop so we ordered up some wrinkle red powder and shot the cover today.
Came out great! I will def be coating my covers in this wrinkle red, and my partner will be doing wrinkle "Laguna Seca" Blue....should be SICK!
Old Apr 4, 2012 | 10:06 AM
L-Fab's Avatar
L-Fab
We'll be doing a couple tweeks to the masking process to clean the lines up a bit, these covers were done quickly as an experiment.. the final ones will have much cleaner lines. We'll also be offering the wrinkle black you see on the plenum in the pics above
Old Apr 4, 2012 | 01:00 PM
Flo-ridaZ33
Do you have a purple wrinkle available?
Old Apr 4, 2012 | 01:05 PM
L-Fab's Avatar
L-Fab
Luckily prismatic carries a huge selection of powders so yes, it is available
