VLSD?
Old Jan 26, 2012 | 05:22 PM
SACZ's Avatar
SACZ
Default VLSD?
Does anyone know if an 05G35 VLSD will work in a 07350Z Base Pumpkin? Also will the stock OEM axle shafts from a 07-08 Enthuziest model fit the 05G35 VLSD?
Old Jan 26, 2012 | 05:44 PM
johnwigs's Avatar
johnwigs
open diff axles do not work in VLSD... VLSD has 1 long and one slightly shorter than the two open axles that are the same... pumpkins are the same
Old Jan 27, 2012 | 12:12 AM
terrasmak's Avatar
Axle shafts are the same, but you will need the proper VLSD stub shafts to do the swap.
Really not worth it, your looking at
$300 for stubs
$120 for fresh bearings and seals
$200 for a driveline shop to set it up (if you hand them just the 3rd member)
$650+ total after fluid etc etc and you have an LSD that offers a max of 30% lock when in perfect form. Over heat it a couple times and its trash.
If you must get a VLSD, you can find a used 3rd member with stubs for $200 to $300 is the best bet.
IMO, save your money and install a real diff, if you need an LSD. A VLSD is only good for driving to and from the grocery store.
Old Jan 27, 2012 | 10:47 AM
bbs350z's Avatar
bbs350z
just get the complete vlsd pumpkin
Old Jan 30, 2012 | 04:24 PM
INTIMAZY's Avatar
INTIMAZY
+1
However, I would go as far as recommending that no Z should be driven without a proper LSD
Old Jan 30, 2012 | 04:30 PM
bbs350z's Avatar
bbs350z
^+1 viscous diff's are junk
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
WalkerT
Dec 3, 2008 05:58 AM
shundal
Northern California
May 2, 2007 04:36 PM
Fairlady_z33
Jun 15, 2006 01:57 PM
