which is trans fluid send and which is trans fluid return?
Old Feb 6, 2012 | 02:59 PM
mgrotel's Avatar
mgrotel
Default which is trans fluid send and which is trans fluid return?
which of these is my auto trans fluid send and which is the return? i want the fluid to go through my radiator cooler first, then my external cooler, then back to the transmission, but to do this, i need to know which of these is send and which is return, thanks
Old Feb 6, 2012 | 05:00 PM
rcdash's Avatar
rcdash
As I recall, the one towards the passenger side is coming from the torque converter and the one towards the drivers side is returning to the transmission.
Old Feb 6, 2012 | 05:23 PM
superchargedg's Avatar
superchargedg
Damn Noobs
I agree.
Old Feb 6, 2012 | 08:22 PM
DaveJackson's Avatar
DaveJackson
Master
You could get an assistant to watch (with a bucket) while you fire it up for a few seconds. The one that squirts should go to the cooler inlet.
Old Feb 7, 2012 | 05:52 AM
mgrotel's Avatar
mgrotel
ok, thanks, ill just follow them back and see if i can tell, or have someone watch for me, thanks
Old Feb 7, 2012 | 05:56 AM
mgrotel's Avatar
mgrotel
how sure are you guys that the pass side is the send? if you arent 100% then ill try to dig into it more, otherwise, if youre sure, ill just take your word, thanks a lot for the help on this
lapham3
Oct 7, 2022 03:15 PM
