Turbo back to NA/Nitrous. 434ci sleeved stroker LSx build.
Old Apr 22, 2012 | 10:36 AM
  #41
Quamen's Avatar
Quamen
Good! That was kind of a simple mistake to make that can kill your motor very very quickly.
Old Apr 22, 2012 | 11:28 AM
  #42
SnyperZ's Avatar
SnyperZ
Very simple. I had to drive 104 miles (round trip) pay 8$ for the part..completely disassemble my car..and then literally POP this thing in in less than 3 seconds. lol
Old Apr 22, 2012 | 01:05 PM
  #43
Quamen's Avatar
Quamen
It's so cheap and easy yet amazingly it's nearly a backbone of engine operation.
Old Apr 23, 2012 | 10:38 AM
  #44
SnyperZ's Avatar
SnyperZ
Absolutely. Going to start on the exhaust tonight. One other thing I might add is switching to twin intake pumps from my magnafuel external was a very good choice. Damn that thing was annoying after about 3 seconds of running.
Old Apr 23, 2012 | 10:48 AM
  #45
phreaktor's Avatar
phreaktor
Design Engineer
Once you did your initial V8 swap, is swapping again just a plug and play deal? Sorry for the noob question.
Old Apr 24, 2012 | 06:59 PM
  #46
SnyperZ's Avatar
SnyperZ
Its all good. And no. The second year I made a turbo kit..the third year I made the tube front end, and this year I went back to NA and had to make a bunch of new stuff.
Old Apr 24, 2012 | 08:05 PM
  #47
Quamen's Avatar
Quamen
Lol. It seems as though Snyper and I have always been the ones who went off the deep end with our LS swaps.
Looking forward to you being done! When do you guess you will have the opportunity to get to the track?
Old Apr 26, 2012 | 07:45 PM
  #48
SnyperZ's Avatar
SnyperZ
New exhaust is on.
http://www.youtube.com/watch?v=91nf_...&feature=g-upl
Still chasing some very f***********************ing annoying wiring/ecu issues so I can't even start break in yet. Will keep updating as I progress.
Old Apr 26, 2012 | 08:06 PM
  #49
Honda2Nismo's Avatar
Honda2Nismo
Absolutely amazing. I'm about to start my swap, I just can't decide which motor to choose.
Good work!
Old May 6, 2012 | 08:18 AM
  #50
SnyperZ's Avatar
SnyperZ
Look what I found. =)
I was having an oil pressure issue from the moment I started the car so for peace of mind I took EVERYTHING back apart and pulled 2 main caps and one rod cap to find this...60 miles into a brand new 14k motor. Didn't bother taking the rest apart.
Old May 6, 2012 | 08:23 AM
  #51
0jiggy0's Avatar
0jiggy0
Ouch, who did the machine work?
Old May 6, 2012 | 08:27 AM
  #52
SnyperZ's Avatar
SnyperZ
ERLperformance.com They sleeved and built the shortblock.
Old May 6, 2012 | 08:42 AM
  #53
Quamen's Avatar
Quamen
Sorry to hear that bro. That missing restrict or plug did a number on your motor.
Old May 6, 2012 | 08:59 AM
  #54
SnyperZ's Avatar
SnyperZ
It sure did. Its all good. I think its time to sell my car and move onto a less stressful hobby. I was thinking about knitting.
Old May 7, 2012 | 11:40 AM
  #55
Brew_haha's Avatar
Brew_haha
HAHAHAHAHA ^^^^ i know how you feel. What are the symptoms that you are having with your wiring?
Old May 7, 2012 | 02:29 PM
  #56
SnyperZ's Avatar
SnyperZ
First of all, ERL has agreed to my terms and will be providing new bearings and new head gaskets and I will gladly pay for the labor. As far as the harness...what wasn't wrong? The terminals were loose--id get codes for injectors not working, wiggle the connectors and those codes would go away and new ones would pop up..wiggle again and different codes. It didn't fit my fast intake manifold, I had to cut and extend half the sensor wires and lastly the 1&3 coil packs were wired backwards causing me to wash a cylinder down. =)) Oh the joys of building your own unique performance vehicle.
Old May 7, 2012 | 06:51 PM
  #57
Vas_Z33's Avatar
Vas_Z33
.. dont scare me like that mark
Old May 8, 2012 | 08:21 AM
  #58
Brew_haha's Avatar
Brew_haha
Who did the harness work? sikky or hinson? let me know if you need any pinouts or anything.
Old May 8, 2012 | 11:35 AM
  #59
bbs350z's Avatar
bbs350z
+1, just hit up logan for the wiring. if you have any custom plugs or anything of the sort they can toss that in too. logan knows his material
Old May 19, 2012 | 02:20 PM
  #60
SnyperZ's Avatar
SnyperZ
I built my original harness using a factory GTO harness. It was getting old so I had a brand new full custom harness with fuse box built by current performance. They are currently redoing the entire harness. They were very cooperative. I should have the engine back in and running within 3 weeks.
Also found this in the mail. =) This is a two stage plate kit specifically designed for the fast 102. Im selling the 10lbs bottle and going to a 15lbs bottle to support both stages. It uses a 6an feed line capable of flowing 800hp worth of nitrous.
