Aftermarket Fuel Rail?
Old Dec 28, 2003 | 12:22 PM
daking350's Avatar
daking350
Default Aftermarket Fuel Rail?
Does anyone know of anyone making an aftermarket fuel rail???
Old Dec 28, 2003 | 12:47 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
None are out yet....why do you feel you even need one? Have you seen the inner diamter of the stock unit.......its more than enough for any sort of realistic power goals.
Easy enough to make though.
Old Dec 28, 2003 | 01:05 PM
daking350's Avatar
daking350
I was looking at adding EXTRA injectors in the rail...
Old Dec 28, 2003 | 03:01 PM
teh215's Avatar
teh215
Where would you add the additional injector? I would think that the best bet would be either replace the OEM injectors with larger injectors, modify the amount of fuel the OEM injectors spray or add the new injectors somewhere upstream in the manifold. Are the stock injectors at 100% duty cycle under boost?
Old Dec 28, 2003 | 03:05 PM
daking350's Avatar
daking350
Well if you ask the guys at ATI they can handle more but I think not....The reason not to go with bigger injectors is I dont want to affect the idle of the vehicle and have to get reflashed for them..I have to see how the piggyback i plan on using will work as far as trimming the pulse on a larger injector...
Old Dec 29, 2003 | 10:22 AM
UnderPressure's Avatar
UnderPressure
I don't mean to sounds like an *** but...
Have you bumped your head?
The ID of the stock fuel rail is about the diameter of a #2 pencil lead. Even @ the increased fuel pressure the stock rail is going to be an restriction in the very near future for the FI guys.
I have talked w/ a few companies about building fuel rails, but w/ my background as a M.E. and machinist I'm contemplating producing them myself.
How much interest would there be in an fuel rail upgrade?
Old Dec 29, 2003 | 10:44 AM
elektrik_juggernaut's Avatar
elektrik_juggernaut
interested
Old Dec 29, 2003 | 12:46 PM
daking350's Avatar
daking350
REQUIRED INTEREST....And if they could be designed to hold an extra 6 injectors that would be cool....if it fits!!!
Old Dec 29, 2003 | 12:55 PM
nigevellie's Avatar
nigevellie
can i get a woo woo?
Old Dec 29, 2003 | 01:08 PM
12SecZ's Avatar
12SecZ
I am interested of course.
Thanks
Old Dec 29, 2003 | 01:11 PM
abogada001's Avatar
abogada001
Im interested.
Robin
Old Dec 29, 2003 | 01:24 PM
daking350's Avatar
daking350
if you make it....They will buy it.....
Old Dec 29, 2003 | 02:04 PM
UnderPressure
Why bother w/ 12 injectors? Just run 6 injectors of the correct size and a good standalone to manage it. We run 2 street cars w/ Bosch 120lb/hr injectors and Autronic. No idle or drivability problems.
It seems like there is enough interest for me to get off my rear and start prototyping.
Would you guys and girls like just a bolt in fuel rail or a complete fuel system upgrade? The stock pump is going to become a problem very soon for a couple of you.
Old Dec 29, 2003 | 02:14 PM
JeffR116's Avatar
JeffR116
Originally posted by UnderPressure
\Would you guys and girls like just a bolt in fuel rail or a complete fuel system upgrade? The stock pump is going to become a problem very soon for a couple of you.
I'm interested. I would say go with a complete fuel system, that way we wont have to deal with replacing the stock fuel pump if we get power hungry.
Jeff
Old Dec 29, 2003 | 03:19 PM
teh215's Avatar
teh215
Additional injectors would require additional holes into the lower intake manifold, right?
Old Dec 29, 2003 | 03:23 PM
abogada001's Avatar
abogada001
All these options.............one minute i'm keeping the Aeremotive FMU then next minute there is something better.............
Is there any consensus on:
1. Keeping it simple - even up to 600hp applications
2. Keeping the cost within reason - this stuff is expensive
enough already(this may be the same as # 1....lol)
3. What about stock ecu functions (A/C etc) if standalone units
are used........or are we almost stuck w/ a piggyback or reflash
These are prob rhetorical questions with a million opinions, but every website I read has tons of good stuff to say about their own ingintion sys, fuel sys, monitoring sys, whatever........so maybe some with experience can assist those moving ahead with new motors.
Thanks
Robin
edit: not to hijack the thread, we can just talk about fuel systems if you want!!
Old Dec 29, 2003 | 05:40 PM
Z1 Performance
Former Sponsor
to keep the stock ecu functions for cold start, idle up, etc, you would wire the standalone in parallel with the factory ecu. In theory it shoudl work fine on the Z, as it ahs worked on countless other cars....will not know for usre till I try it next year.
As for additional injectors from a single rail, how would you do this? As mentioned above, you would need additional mounting bosses in your heads. Fitting bigger injectors is really not a big deal at all, especially if you have a form of auxiliary fuel control. Idle is really the least of your probelsm, as the injector is barely opened at idle in the first place, though it will obviously depend on how big of an injector you intend to fit.
I'll go measure the stock fuel rail diameter tomorrow
Old Dec 29, 2003 | 09:04 PM
12SecZ's Avatar
12SecZ
I am just interested in an AEM type fuel rail only. Different colors would be cool. Does ours show?
Old Dec 29, 2003 | 09:05 PM
daking350's Avatar
daking350
NOPE....
Old Dec 29, 2003 | 09:19 PM
elektrik_juggernaut
They're in that V-shaped channel underneath the plenum
