Upgrade to cd009 transmission
oh masters of my350z, I can use some help with figuring out the upgrade to a cd009 transmission for my Z. I've done lots of searching and read all the relevant posts I could find but I am still a little unclear.
On one hand I read a cd009 is a cd009 regardless of the year. On the other I've read that there are some compatibility issues. So what is the final answer for this? And are there any other parts I need to replace if I go with a used transmission. Or parts I will need to swap over if I buy a new one?
My Z is a 2003.
In exchange for information I promise to put up a swap your transmission DIY, like the one I did for replacing the front wheel bearing.
My Z is a 2003.
Look into shift fork and pivot ball differences between 2003 and 2004+
http://www.conceptzperformance.com/C...&Car_Type=350Z
on
the only compatibility issues there are is the newer transmissions that have the concentric slave. All of the de manual trans will fit on all of the DE engines with no problems. Like the post above states make sure you put the correct length pivot ball. I think importpartspro.com sells them and lists which one requires which pivot ball.
Thanks for the replies. So any de cd009 will work. And I assume all cd009 require the shorter pivot ball since the cd009 is '05+?
Any thoughts about upgrading the shifter fork in addition to the pivot ball? Is it really at risk of breaking with an upgraded clutch?
on
I think the 009 uses a shorter one. I don't know since mine was upgraded by the dealership they automatically put the correct pivot ball in there.
no, those transmissions are all 05 and older for the DE's. The cd001-cd009 is the same transmission but just upgrades on the inside. They are not used on the HR. That's a different version all together.
Mic posted this a while back:
2003 6MT
Double cone synchronizers in 1st and 2nd
No triple cone synchronizers
2004 6MT
Double cone synchronizers in 1st, 3rd, 4th
Triple cone synchronizer in 2nd
2005 CD008
2005 CD009
Double cone synchronizer in 4th
Triple cone synchronizer in 1st, 2nd, 3rd
2003 6MT
2004 6MT
2005 CD008
2005 CD009
on
More questions.
Also, does anyone know if the requirement for this shorter ball is related to the clutch slave cylinder? It appears the 2003 use a 30610-CD00A and the 2004 and above use a 30620-CD00B.
Lastly, I saw in another post that the 2003 transmission has a different shifter bracket (aka control lever HOUSING ASSY-CONTROL LEVER) and I will need to make sure the used transmission comes with this bracket. Can anyone confirm this?
Thanks in advance.
Yes, when I picked it up from the salvage yard it still had the clutch fork and pivot ball there, so technically I dont need to replace it, however, I will probably still replace them so that I dont have to worry about them failing on me ever and screwing up the tranny.
