Swapped my rear end with an LSD unit from an automatic
Old Jun 17, 2012 | 07:43 PM
Marrocco350z's Avatar
Marrocco350z
Default Swapped my rear end with an LSD unit from an automatic
Blew up my stock open diff the other night so I replaced it with an LSD from an automatic. I can honestly tell the difference in handling but read about problems with speedometer and my added cruise control that worked with my old diff no longer functioning. Sure enough no cruise control and speedometer seems off.
I know I can swap the LSD from the 3.5 into my housing. I want to know is there any other way to fix the cruise control issue and speedometer issue other then having to swap the internals of the rear end?
Old Jun 18, 2012 | 04:04 AM
mvp2765's Avatar
mvp2765
There's no other way unless you swap internals or the rear end
Old Jun 18, 2012 | 09:43 AM
bbs350z's Avatar
bbs350z
your car should be feeling slower too, as the gearing in the auto is a 3.3 vs the 6mt's 3.5
Old Jun 18, 2012 | 10:16 AM
terrasmak's Avatar
Speed is the same, speed goes off your wheel speed sensor , gear ratio doesn't matter. Cruise control, don't know, I know mine still works with 3.7 gears
Old Jun 19, 2012 | 08:38 PM
Marrocco350z
The car feels amazing on the highway and down low you just have to remember to keep the revs up! I have an HR with a light weight flywheel and it's decently rev happy
Old Jun 19, 2012 | 09:13 PM
black03350z's Avatar
black03350z
im not 100% on this but i think the prob is the sensors that track tire speed. i had the same prob when i put extreme low profile tires on rear as a temp thing and still had reg tires on front. my cruse didnt work and traction control didnt work either. when i swapped them back, everything worked again.
So i believe that the car could just be sensing diff tire speeds and it thinks theres a problem with the car and disables that function.
Old Jun 20, 2012 | 07:23 PM
Marrocco350z
Yeah I understand this, my question is there away around it? Maybe through engine management such as UpRev?
Old Jun 21, 2012 | 03:03 PM
redline06's Avatar
redline06
wait you had a stock open dif but also have cruise control? only ones with an open diff are base models but they don't come with cruise control. unless of course you installed CC into a base model or if someone removed your V.L.S.D and put an open diff in your Z lol
May 30, 2017 03:28 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
pr_350z
Oct 1, 2015 05:03 PM
samansharif
Sep 25, 2015 12:31 PM
