Need an answer--NISMO R Tune Cams
Old Jan 14, 2004 | 10:15 AM
FairladyZ's Avatar
FairladyZ
Jeff,
Which cams got the best gains? how much do you charge to have a cam install done?
Old Jan 14, 2004 | 05:32 PM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
Originally posted by FairladyZ
Jeff,Which cams got the best gains? how much do you charge to have a cam install done?
The Tomai and Nismo's are the only ones we've played with. We charge $700 for the Nismo install and around $800/$850 plus shims for the Tomai since we need to so much adjustment to them. The Tomai seem to idle rougher than the Nismo and gains seem about the same. Problem is the cars ALL act different on the dyno. I can't get two baselines the same on two different cars!!
KJY9's Avatar
KJY9
Originally posted by 350zSpeedRacer
I want to know what I'm getting into before I buy something. I could find all the info I needed on the NISMO cams, and they were actually a really good fit for what I'm trying to build.
I can't tell you how long I spent searching for info on Tomei's cams with absolutely no luck.
Christi....as much as you wrench I think I'm just going to drop my Z off at your place with a set of cams. You can practice on mine if you like?!?
Old Jan 15, 2004 | 05:40 AM
350zSpeedRacer's Avatar
350zSpeedRacer
I can promise you I could easily take the whole engine apart (with a little help from hubby for those bolts torqued down more than my body weight--lol), but I always seem to end up with a few extra parts when I put things back together. But I'll be more than glad to tinker around if you'll let me.
Old Jan 16, 2004 | 06:21 AM
KJY9's Avatar
KJY9
LOL...hmmm let me ponder that for awhile
Old Jan 16, 2004 | 10:14 AM
mcduck's Avatar
mcduck
What's to ponder?! You get the work done... so what if there are left over parts. They probably weren't necessary and think of the weight you are saving!
I'd have Christi fix up my car except... well... it's already done. Maybe for the SC or TT kit...
Old Jan 16, 2004 | 07:50 PM
KJY9's Avatar
KJY9
as much as I've been screwed around on this car by people that "supposedly" know what they're doing, I'd actually trust her more than some that have had their heads and hands under my hood.
What have I got to lose right? LOL
2ndchanceZ
Oct 26, 2015 08:03 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
