350z awd build!
Old Mar 27, 2013 | 03:13 AM
MURDAH350's Avatar
MURDAH350
Default 350z awd build!
so recently i was working at my buddys shop when i noticed an engine/drivetrain sitting in the corner. after looking at it for a second i thought the motor looked shockingly similar to a VQ. i asked him what it was and much to my dismay he informed me that it was the complete drivetrain from a g35x. well of course i went from 6 to midnight right on the spot. he told me i was more than welcome to the parts for virtually nothing. SO!! TO THE POINT!
I have been doing some research and have come up with an amazingly small amount of information. does anyone have any previous experience with the g35x or any sort of similar swap? not many people doing this kind of swap. what necessary parts/fabrication would theoretically be involved? I am already running FI 450ish to the wheels so the additional weight would not be too big of an issue. ANY ADVICE/KNOWLEDGE IS GREATLY APPRECIATED!!!!
Old Mar 27, 2013 | 03:21 AM
Quamen's Avatar
Quamen
It was done by function tuned a couple years back. I believe they needed the g35x front suspension, g35x ECU, and a modified g35x cross member. I do know that just the electrical portion was quite a pain since its an auto trans.
Old Mar 27, 2013 | 03:27 AM
MURDAH350's Avatar
MURDAH350
you wouldnt happen to know if the "transfer case" is compatible with manual transmissions would you? or would i have to swap over to an automatic? that would definitely ruin my perspective on things.
Old Mar 27, 2013 | 04:22 AM
MUZZY's Avatar
MUZZY
done before by function tuned and you need everything on the front end of the g35x
Old Mar 27, 2013 | 05:12 AM
revolvedZ's Avatar
revolvedZ
my favorite example is the jun version, but that was race car... alot different then the function version... but your looking at crossmember, transfer case, only the front diff/oil pan as for motor, trans setup im a little rusty on, and for wiring/ecu, im thinking you can bypass all sensors/switches in the transfer case and go for a more classic awd setting.
neat for sure... but i hope you have your fabrication pants on
edit: has to use auto trans from g35x, unless you use a gtr trans with adapter plate
Old Mar 29, 2013 | 03:44 PM
Resmarted's Avatar
Resmarted
If you want manual I'm pretty positive you'll need a tranny from a r32-4 GTR.
And yes, you're right there really is too little info out there.
If I had the parts on hand I probably would have attempted to add it to my build. I don't think my turbo setup would work with an awd conversion though.
Old Apr 5, 2013 | 10:08 AM
Tackett's Avatar
Tackett
My wife's Infiniti ex35 is an AWD. And it has the HR engine in it.
Side by side they look identical, it wouldn't shock me if it was built on the 350 frame.
Old Apr 5, 2013 | 11:42 AM
binder's Avatar
binder
Since it's unibody there is no "frame" and the design on the fx's came from the g35's not the 350z. 350z has too short of a wheel base for an suv.
If you get the auto transmission built to handle the 400hp then I would assume the next thing to go would be the transfer case as those are designed for less than 300hp.
Old Apr 6, 2013 | 03:53 PM
Tackett's Avatar
Tackett
Notice I said EX. Not FX.
The EX isn't a full size SUV. It's basically a wagon.
http://www.edmunds.com/infiniti/ex35/2008/
According to edmunds, it is based off the g35 platform and the wheelbase isn't even 2" longer.
Old Apr 8, 2013 | 09:07 AM
binder's Avatar
binder
oh, even the EX is based off the g35 not the 350z like you stated before. So it has longer driveline components than the 350z.
Old Apr 8, 2013 | 02:38 PM
Tackett's Avatar
Tackett
Yeah it is. I was trying to say you were right and I was wrong. My communication skills suck. Just ask my wife.
Old Apr 10, 2013 | 04:46 PM
binder's Avatar
binder
lol, no worries
Old Apr 16, 2013 | 03:43 AM
ZZZ-35's Avatar
ZZZ-35
Default Done Already
It's been done there in Queensland Australia, lookup his thread on the other 350 site://www.xxxxxx/forums/148-australia/70358-awd-z.html
Cheers
Old Apr 16, 2013 | 12:42 PM
Resmarted's Avatar
Resmarted
Cheers
Didn't go through....
You can pm me a hint on how to make that link work
Old Aug 20, 2013 | 03:26 AM
qikz's Avatar
qikz
Cool
Just PM qikz for the first hand report. The R&D Journey has been expensive but VERY interesting. Its presents as a factory Z38X TT (I call it) and is thrilling to drive.
I am very close to offering a kit which retains ALL factory electronic functions and appears stock from inside and underneath and would only take a long weekend to install.
Old Feb 13, 2014 | 07:59 PM
overZealous1's Avatar
overZealous1
i would be willing to give ya some money just for the parts list. i am looking at doing it in a g35 coupe chassis.
Workshop12
Mar 23, 2020 01:45 PM
davidm350
Oct 31, 2015 02:28 PM
RiujinZero
Sep 25, 2015 01:19 PM
_koubie_
Sep 20, 2015 06:34 PM
