Differential Bushing ???
Old May 7, 2013 | 09:48 AM
Gianky's Avatar
Gianky
Default Differential Bushing ???
Here goes, one of my rear diff bushing is leaking, so I'm about to buy and do the install...
Which way should I go?
My car is a daily driver, everything is stock for the moment, but comfort and drive-ability is my priority.
Should I go with Whiteline, Sikky or SPL? -> polyurethane / solid
Old May 7, 2013 | 02:23 PM
bmyles's Avatar
bmyles
Whiteline if you don't want as much drivetrain whine. I have Whiteline and it adds whine at 40mph and above, but it's not horrible. I believe with solid bushings, it will be much more noticeable.
Old May 7, 2013 | 06:28 PM
harman850t5's Avatar
harman850t5
You can hear my diff whine from 40-65ish with the spl solids. It can get annoying. I also have whiteline subframe bushings too though.
Old May 7, 2013 | 07:24 PM
Gianky's Avatar
Gianky
So for a daily driver (being my work transport) will it be way too annoying?
Old May 7, 2013 | 07:25 PM
Gianky's Avatar
Gianky
Ok, thanks. so solids are out of question here...
Old May 8, 2013 | 03:49 AM
bmyles's Avatar
bmyles
I have no way of telling what annoys you. I drive my car every day 35 miles round trip and I'm fine. If you have music on, it's less noticeable.
Old May 8, 2013 | 05:11 AM
djamps's Avatar
djamps
I have SPL solid bushings and SP diff brace on my G (after my energy diff bushing failed and ejected itself on the track the first time running them hard -- ES compression rod bushings also failed in less than 5k miles, now replaced with whiteline). The whine isn't bad at all, probably wouldn't hear it with a aftermarket exaust or music turned up, but again it's a G with a trunk to help isolate the noise. I imagine it's noisier on a Z. If you do poly stick with whiteline. Please avoid ES bushings of any kind.
Old May 8, 2013 | 01:09 PM
Gianky's Avatar
Gianky
just ordered the whitelines, thanks for the advices!
hulkout
Apr 28, 2017 09:00 PM
CJs_Z33
Sep 18, 2015 12:06 PM
Suffolk350z
Sep 13, 2015 02:43 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
