transgo Shift kit install, is gear selector stiffness normal???
Old May 8, 2013 | 01:44 AM
black03350z's Avatar
black03350z
Default transgo Shift kit install, is gear selector stiffness normal???
Anyone that has has a transgo shift kit install please leave some feedback...
My 350z automatic has just had a transgo shift kit installed and everything seems to operate fine except that the gear selector is very stiff/heavy. Once its in gear it shifts through all gears fine. just getting it from park to any other gear is far more difficult than it was before the kit was installed. i see no clear binding issue with linkage outside tranny or inside where linkage passes behind valve body.
Is this a normal issue or should i be a lil concerned???
Old May 8, 2013 | 05:48 AM
JCITY's Avatar
JCITY
I've got a Transgo.Don't have the "stiffness" you are taliking about.
The Transgo is an internal valve mod.Should not effect the mechanics
of moving the shifter.I also changed my OEM shifter to a Momo
unit.However,had the OEM shifter installed when I had the Transgo mod
done.The Momo made no diff in ease of moving the shift lever.Its just
more ergometric and looks better too!
Old May 8, 2013 | 09:46 AM
superchargedg's Avatar
superchargedg
Damn Noobs
I also have the transgo and have no stiffness in the shifter at all.
Old May 9, 2013 | 05:04 AM
VQpwr03z's Avatar
VQpwr03z
I had the transgo kit on my previous Z and no stiffness at all.
Old May 10, 2013 | 05:23 AM
black03350z
thx for the feedback guys!! i wonder what it could be? any tech guys out there have an opinion?
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
codek
Sep 28, 2015 03:03 AM
