removing bellhousing from transmission
Old May 16, 2013 | 06:46 PM
estomax's Avatar
estomax
Default removing bellhousing from transmission
Hey Guys,
I am looking at the FSM for a 2004 350Z and I am seeing that it guides you to have to take apart the whole rear of the transmission to remove the bellhousing from the transmission. I am going to need to remove just the front bellhousing to have 5/8" machined off (or does anyone know a machine shop that can to it without taking the transmission apart??) for using this on a 1JZ motor
For people that have taken these apart before, does the front half of the bellhousing come off without removing the shifter and all the little bits in the tail end of the transmission? or do i have to remove the tail end first?
thanks!
Marko
Old May 17, 2013 | 12:38 AM
harman850t5's Avatar
harman850t5
You can remove front only. Just did this a few weeks ago. But you're definitely better off doing both as you'll have to reseal the rear half anyways as it also starts to split off
Old May 17, 2013 | 04:20 PM
estomax's Avatar
estomax
got the bellhousing off, it just needed some more jiggling at an angle it it popped right off. what is this plastic piece sitting inside the transmission near the shift rod for?
cheers
Marko
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
