are these thing known to leak? im having some acceleration issues that i thought may be do to a vacuum leak, but a leak in the plenum would have the same symptoms?
The Crawford plenum itself does not have a tendency to leak, but it may be leaking around the base. If I remember correctly when I installed mine 9years ago, it was recommended to use 2 plenum gaskets to insure a good seal between the upper & lower plenum.
