Messed with Yaw/G Sensor
Old Oct 21, 2013 | 02:45 AM
350DTX's Avatar
350DTX
Default Messed with Yaw/G Sensor
okay so i tried doing the VDC Switch delete on my 2004 Daytona Blue 350z. So basicly what i did was i cut the orange wire that goes to the Boshc unit when i did that my VDC Light and slip ligh came on like it was supposed to... i then later said i didnt want to do that mod no more so i blacked taped the wire together and even thoe i turn on and off my car the lights wont go off not even if i hot the VDC Button... So now ive been driving with no traction and my question is do u think i wll need a new yaw sensor? or am i doing something wrong?
Old Oct 21, 2013 | 07:02 AM
kaze06's Avatar
kaze06
I think the first thing you did wrong was try to remove the VDC switch for no reason.
Try disconnecting the battery and waiting a half an hour and see if it resets.
Old Oct 21, 2013 | 07:40 AM
travlee's Avatar
travlee
Master
good times.... i would not electrical tape it, but instead use a butt connector to attach it back.. you might need to reset the ecu
Old Oct 21, 2013 | 08:56 AM
SQuaLZ's Avatar
SQuaLZ
butt connector FTW!
As the others have said reset the ecu after you reconnect the wire and you should be good.
Old Oct 21, 2013 | 08:58 AM
travlee's Avatar
travlee
Master
haha, guess i could have said crimp connector
Old Oct 21, 2013 | 09:10 AM
SQuaLZ's Avatar
SQuaLZ
lol I call it butt connector also. Used them to connect my chip to my ecu on my Civic when I boosted her.
Old Nov 24, 2013 | 03:01 PM
350DTX's Avatar
350DTX
lol thank you guys for all of your opinions of knowledge ive tried disconnecting the batter for 30 minutes even a day and i still have those same lights on and used the crimp connector but there is no use. how would i reset the ECU for that cause i know theres specific ways to reset the ecu for different things such as the throttle body etc...
Old Nov 16, 2016 | 11:01 AM
Nabice's Avatar
Nabice
Hate bumping an old thread but did you ever figure out what happened
Old Nov 16, 2016 | 11:48 AM
travlee's Avatar
travlee
Master
he hasnt logged in going on 2.5 years
liqalu04
Jan 2, 2022 12:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
350Z Project X
Oct 17, 2015 05:16 PM
