anyone know what dtc p2138 means?
Old Jan 29, 2004 | 07:27 AM
noahbuddy's Avatar
noahbuddy
Default anyone know what dtc p2138 means?
Just got the J&S Timing controller installed and now if I start the car quickly I get a dtc. I've cleared it twice, but it keeps coming back.
Anyone know what they mean?
p2138
emmissions related codes
p00
p3800
Old Jan 29, 2004 | 07:39 AM
alex30327's Avatar
alex30327
DTC P2138 APP SENSOR =accelerator position sensor
Component Description
The accelerator pedal position sensor is installed on the upper end of the accelerator pedal assembly. The sensor detects the accelerator position and sends a signal to the ECM.
Accelerator pedal position sensor has two sensors. These sensors
are a kind of potentiometers which transform the accelerator pedal position into output voltage, and emit the voltage signal to the ECM. In addition, these sensors detect the opening and closing speed of the accelerator pedal and feed the voltage signals to the ECM. The ECM judges the current opening angle of the accelerator pedal from
these signals and controls the throttle control motor based on these
signals.
Idle position of the accelerator pedal is determined by the ECM
receiving the signal from the accelerator pedal position sensor. The ECM uses this signal for the engine operation
such as fuel cut.
CONSULT-II Reference Value in Data Monitor Mode ABS000X7
Specification data are reference values.
*: Accelerator pedal position sensor 2 signal is converted by ECM internally. Thus, it differ from ECM terminal voltage.
On Board Diagnosis Logic ABS000X8
This self-diagnosis has the one trip detection logic.
FAIL-SAFE MODE
When the malfunction is detected, ECM enters fail-safe mode and the MIL lights up.
PBIB0146E
MONITOR ITEM CONDITION SPECIFICATION
ACCEL SEN1  Ignition switch: ON
(Engine stopped)
Accelerator pedal: Fully released 0.5 - 1.0V
Accelerator pedal: Fully depressed 4.0 - 4.7V
ACCEL SEN2*  Ignition switch: ON
(Engine stopped)
Accelerator pedal: Fully released 0.3 - 1.2V
Accelerator pedal: Fully depressed 3.9 - 4.8V
CLSD THL POS  Ignition switch: ON
(Engine stopped)
Accelerator pedal: Fully released ON
Accelerator pedal: Slightly depressed OFF
DTC No. Trouble diagnosis name DTC detecting condition Possible cause
P2138
2138
sensor circuit
range/performance
problem
Rationally incorrect voltage is sent to ECM
compared with the signals from APP sensor 1
and APP sensor 2.
 Harness or connector
(The APP sensor 1 and 2 circuit is open
or shorted.)
 Accelerator pedal position sensor 1 and
Engine operating condition in fail-safe mode
The ECM controls the electric throttle control actuator in regulating the throttle opening in order for the idle position to be within +10
degrees.
The ECM regulates the opening speed of the throttle valve to be slower than the normal condition.
So, the acceleration will be poor.
Workshop12
Mar 23, 2020 01:45 PM
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
issyz
Jul 2, 2017 03:04 PM
torchkc
Sep 11, 2015 08:26 PM
