jwt combo engagement point.
Old 12-11-2013, 12:21 PM
max-hid
max-hid's Avatar
Default jwt combo engagement point.
I have an 04 350z and recently changed the stock flywheel / clutch to a JWT clutch combo. I have been driving it around very easily for about 200 miles. I also changed the clutch master and slave cylinder with a new throwout bearing, pilot bushing, and new pivot ball.
The problem I am having is that the clutch engagement point is very low. the clutch pedal refuses to spring back to its intended position, It stops halfway in between.
I also noticed that there is about an 1-1.5" of free play in the clutch pedal before I actually feel the pressure on the pedal. Is this normal?
Old 12-11-2013, 12:23 PM
Premier MemberSuper Moderator
terrasmak's Avatar
Received 2,333 Likes on 1,681 Posts
Sounds like air in the system or you have the wrong pivot ball and fork combo.
Old 12-11-2013, 01:04 PM
travlee
Master
travlee's Avatar
Received 9,155 Likes on 6,603 Posts
mine did this when i changed out to the wilwood master.... you can adjust the fork arm some to take out the slack..... like terrasmak said you could also have air in the line
Old 12-11-2013, 04:53 PM
max-hid
max-hid's Avatar
I will try bleeding again... the pivot i put its the same size as the oem one...
Old 12-11-2013, 05:00 PM
92K1500
92K1500's Avatar
I replaced my stock with JWT, new pivot ball, stainless braided hose, new TOB and roller pilot and cleaned everything up. Bled it all out and mine starts to grab about 1/3 of the way up as usual I believe. I don't really think about it. But the pedal goes all the way to the top like it should.
Old 12-12-2013, 04:38 AM
max-hid
max-hid's Avatar
Today i will install braided hose and will bleed again... hope tgat solve the problem... i will buy a vaccum pump to bleed it..
Old 12-12-2013, 04:39 AM
travlee
Master
travlee's Avatar
check the rod on the master, you can unscrew it some if there is still some slack after you bleed it again
Old 12-12-2013, 04:50 AM
max-hid
max-hid's Avatar
Perfect... i will try all today and update tonight
04-22-2021 09:42 PM
11-09-2020 10:27 AM
sherm
04-11-2020 05:21 PM
EnjukuRacing
09-30-2015 06:55 AM
Tochigi_236
09-27-2015 03:40 PM
Quick Reply: jwt combo engagement point.
