Single upper harness connectors needed
Old Jan 29, 2014 | 07:09 AM
Z33Garage's Avatar
Z33Garage
Default Single upper harness connectors needed
I am trying to see if any of you guys know if any vendor or e-store carries individual connectors for the DE upper harness. I noticed that my pass camshaft pos sensor connector does not click close and upon closer inspection the clip is broken. This also is the same case for the cyl #4 ignition coil pack connector.
For the time being I zip tied the connector tight to the coil pack/ camshaft sensor themselves to not allow it to inch out as the engine moves with use.
The price for a used harness online seems rather steep just to replace these 2 connectors so if thats my only option I think I will keep the ties in place, unless one of you all can help me.
Thanks.
Old Mar 20, 2014 | 10:08 AM
eZg's Avatar
eZg
Did you ever find one?
I've got inquiries in all over the place including chasebays, dynosty, etc...,
George
Old Mar 20, 2014 | 10:17 AM
eZg's Avatar
eZg
any know if this will work for Cam Position sensor CLIP???
http://www.chasebays.com/product/con...e-2p-connector
Thanks
Old Mar 20, 2014 | 11:04 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
^no. that is for the altenator and is a huge clip.
The cam pos sensor clip is a 3 wire
The cam pos sol clip is a 2 wire
I have a ton of sensor clips just let me know which ones you need. I had 2 harnesses that I used clips off of for my wire tuck and extension.
Old Mar 20, 2014 | 11:11 AM
eZg's Avatar
eZg
Awesome!! PM sent along with Karma blessings
Old Mar 21, 2014 | 05:32 AM
eZg's Avatar
eZg
wondering if this may work.....
http://www.chasebays.com/product/con...k-3p-connector
Old Mar 21, 2014 | 05:59 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
^thats exactly what I have for you.
Old Mar 21, 2014 | 06:05 AM
eZg's Avatar
eZg
Great!
Perhaps now recorded for future folks.....
Old Mar 21, 2014 | 06:09 AM
Z33Garage's Avatar
Z33Garage
I love you people. That is the exact part I need. I will check if they have the connectors for the spark plug igniters.
Old Mar 21, 2014 | 06:23 AM
eZg's Avatar
eZg
Love you long time....not as long as your valve cover video though
http://www.bmotorsports.com/shop/pro...oducts_id/2175
Old Mar 21, 2014 | 06:27 AM
Z33Garage's Avatar
Z33Garage
LMFAO! I have been know to talk alot when trying to teach others.
Thanks guys, I will make a 45min video on how to solder these into the harness. ( I will be like the nutnfancy of Z repairs)
Old Mar 22, 2014 | 06:36 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
I have a ton of Coil pack/igniter 3 wire clips.
Old Mar 24, 2014 | 09:01 AM
str8dum1's Avatar
str8dum1
will this fit on the cam sensors as well as the crank?
Old Mar 24, 2014 | 09:21 AM
eZg's Avatar
eZg
From the looks of it. I'll find out this week.
One of the sensor housing on each side has a notch cut in it. Guessing to keep from hooking up backwards.
Old Mar 25, 2014 | 04:04 AM
eZg's Avatar
eZg
Well phuk a duck.....
The guides or groves on the sides of the housing are offset higher on the green clips where as these other are more towards the center. Juuuustttt enough to where they are not interchangeable.
Need one green clip to get rolling.
Old Mar 25, 2014 | 04:38 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
can you shave the outer guide tab on the sensor leaving just the center one? That should be the fix.
Old Mar 25, 2014 | 06:48 AM
eZg's Avatar
eZg
Thinking of getting a new sensor and adhering this clip to it......as a backup plan to dremiling the housing.
course....it would be nice to use a glue that will not burst into flames at the high temps my twin turbo engine bay get to.....
also trying to figure out if any of the maximas may use the same clip.
Green seems to be a common color for Nissan to use for it's CPS clips....hope they shared same housing size and shape as well.
Thanks for your help Chris!
Old Mar 25, 2014 | 07:06 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
They used green and black
You should be able to shave a pair of the wings down to make it work.
Its like there are 3 positions for the wing pairs. Upper, center and lower. All have the center. When you slip the clip on without modifying the sensor it is 180 out since it will only go on to the lower and center wings when you need it to go onto the upper and center wings.
Remove the lower wings to where only 1 set of wings remains (the center) and then clip it back on.
Worth a shot.
Old Mar 26, 2014 | 05:26 AM
eZg's Avatar
eZg
Got one together!!! have not tested it , still waiting on some other parts.
Ended up dremeling off the top wing on the sensor AND the wing/glides in the middle of the housing.
Chasebays has been out of stock on the green connectors for 7 weeks.......
I appreciate all the help guys!
Old Mar 26, 2014 | 05:33 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
as long as it clips on you should be GTG. Even dremeling all the wings off the sensor.
As always...pics are a must!
