rest ECU Question
Old Jan 31, 2004 | 04:54 PM
MotiCarmona's Avatar
MotiCarmona
Default rest ECU Question
what would be the fastest easiest way to rset your ECU??
Old Jan 31, 2004 | 09:01 PM
Da Gimp's Avatar
Da Gimp
http://www.technosquareinc.com/350reset.htm
Old Jan 31, 2004 | 09:46 PM
phile's Avatar
phile
I'm slightly confused, after the step for resetting the ECU, It gives more instructions for Accelerator Pedal Release Position Learning, Throttle Valve Closed Position Learning, and Idle Air Volume Learning (Throttle Position Learning). What exactly are they for?Are these to be performed everytime the ECU is reset?
Old Jan 31, 2004 | 11:23 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
Easiest way: Unplug the negative battery terminal overnight.
Old Jan 31, 2004 | 11:35 PM
12SecZ's Avatar
12SecZ
The other two are useful say , if you disconnect your TB, IIRC we did this when we did my N20 install so it came in handy, it will relearn over time anyway. Good link though, I had never saw that, I have the timing down so well it's in my head now, I can get into programming mode first time every time w/o instructions.
Maybe this isn't a good thing to brag about ha-ha!!
issyz
Jul 2, 2017 03:04 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
