Clutch fork/Release bearing "SPRING HOLDER" seems to have broken
Old Mar 25, 2014 | 12:00 PM
McLovin350Z's Avatar
McLovin350Z
Default Clutch fork/Release bearing "SPRING HOLDER" seems to have broken
So yesterday my car stalled out and died on me
After getting it towed home i place a code reader on the car.
I recieved P0335 and i went str8 to Advance for a replacement crankshaft position sensor.
After i completed the removal of the sensor, i heard alot of noise.
After taking a light to the hole i found a piece of a clip in my bell housing.
I swapped the sensor just cause and my car works fine now....
My concern is that i might have other loose portions of the spring holder in my bellhousing......i will try to boroscope and remove them.
But if the spring is completely trashed and i can remove it........is the car still safe to drive?
Note: the spring i believe it be is part #3 in the photo
Attached Thumbnails Clutch fork/Release bearing "SPRING HOLDER" seems to have broken-trans.jpg
Obadabot
Jun 18, 2023 11:31 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
