Boost gauge MAP sensor HELP!!
Old Apr 30, 2014 | 01:41 PM
bmueller91's Avatar
bmueller91
Default Boost gauge MAP sensor HELP!!
I just recently purchased a TT 350z. I realized it didn't have an accurate boost/vac reading and would never pass zero and would usually idle around 9. I found where the line was coming off the intake and followed it back into the car. Right before the line goes into MAP sensor it tee's off and that line continues to the back of the car. If i kink that line while the car is running the vacuum goes to a normal 18-19. Does anyone know what this line could be or what its used for?
Old Apr 30, 2014 | 03:07 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
got meth?
Old Apr 30, 2014 | 03:28 PM
bmueller91's Avatar
bmueller91
Originally Posted by Cux350z
got meth?
no.
Old Apr 30, 2014 | 04:05 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
did it have meth?
FPR in the rear?
Old Apr 30, 2014 | 04:24 PM
bmueller91's Avatar
bmueller91
did it have meth?
FPR in the rear?
The FPR is under the hood. and I don't think it was ever meth/water injected. Im going to ask the previous owner to make sure. So the MAP sensor sends the signal to the sensor module which then sends the info to the boost gauge...Is having a hose tee'd into the boost line going into the map sensor consistent with having meth//water injection?
Old Apr 30, 2014 | 05:05 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
looking at your car it looks like you have a vac signal and 2 large wires headed to the rear. The only logical thing is a meth tank with a vac activated signal.
The map sensor takes the vac signal and converts it to and electrical signal that your gauge can understand.
Trace the tube and wires. It should not be open at the other end..thats a vac leak
liqalu04
Jan 2, 2022 12:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
