03 with blown motor.. What all will fit??
on
I have a 03 350z with blown motor. What all year make and model engines from other cars will fit? Also, mine is a manual trans. Will a motor from a automatic work with my trans, will my flywheel bolt right up?? Thanks im in a bind!
General & DIY Moderator
You'll need an 03-05 VQ35DE to fit the wiring harness and ECM of your Z. You can also look at the VQ35DE in the Infiniti G35. Not sure about engines that came with an automatic, although the flywheel should bolt up after you remove the torque converter.
on
ok so I can go up to 2005 cars? How do I know if its a high rev engine or not? My car is a forth digit A car.
Retired Admin
'03-'05 350Zs except 35th Anniversary and '05 Track models have non-revup. '06 automatics also have non-revup. G35 years are slightly off but once you start looking for an engine, you're not going to be searching for specific years so it really doesn't matter what cars came with what.
The easiest way to tell the difference is the timing chain cover. Non-revup on left and revup on right in the below pic.
