Trouble with the engine! Spark plug maybe?
Old Oct 28, 2014 | 02:11 PM
jbvalledorz33's Avatar
jbvalledorz33
Default Trouble with the engine! Spark plug maybe?
Me and a buddy just changed my oil and replaced the spark plugs on my 05 de, I start the car up but it now makes this rattling slash bubbly noise and I'm at a huge torque loss. Car vibrates while its running and it smells rich also.
Any suggestions or thoughts? I really need to make this work normally again
Old Oct 29, 2014 | 08:39 AM
350z006's Avatar
350z006
Maybe put the plug wires back in the wrong order?
Old Oct 29, 2014 | 01:22 PM
FOOKhonda's Avatar
FOOKhonda
Make sure your strut bar isn't touching the plenum, it will make that sound/vibration if its touching.
Old Oct 29, 2014 | 06:36 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Your plugs are not firing cleanly. What brand and model of plugs did you replace the OEM ones with? Recheck the order they were connected and make sure the coil packs are properly connected.
Old Nov 10, 2014 | 08:46 PM
CNunes_95's Avatar
CNunes_95
What brand spark plugs did you use? I have bosch iridium plugs in mine and work just fine. However, the owner's manual recommends platinum plugs. Your motor may not be running as efficient as it should be if it's running rich. Could possibly be a cylinder misfire??? Check to see if all the plugs are properly gapped as well. Should also add a small dab of anti-seize lube on the threading of the spark plug before installation. Then make sure all the connectors are back in place as they were before. Not sure if it helps, but that's really all i could think of.
Follow my Instagram!! @CNunes_95
Old Nov 14, 2014 | 08:17 AM
HK350 Z's Avatar
HK350 Z
My guess would be spark plug gap wasnt checked....
Old Nov 14, 2014 | 08:47 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
No check engine light?
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
