CEL ON!!! NO air coming out from vents!
Old Dec 25, 2014 | 05:56 AM
nachospizza's Avatar
nachospizza
Default CEL ON!!! NO air coming out from vents!
HI everyone, couple days ago I was driving on a rainy day everything normal and I step on it and it reaches 150-160km afterward both of my TCS OFF, SLIP and CEL light came on! So I parked my car and turn it off for like 15 mins, switch it on and the TCS OFF and SLIP light are off. But the CEL light still on and I found out there aren't no wind coming out from my AC vents when I switch on the Fan switch. And I opened my hood and found out both of my fans are not working.
So these couple days I drive local car runs great, temperature didn't goes up except no fan no wind from the vents. I wonder if I am still OK to drive it to the shop which is half an hour away without my fans working??? I check the fuse box in front of the battery and I don't see any fuse are blown... should I check the relay and how can I tell if those relays are not working? Also other than this fuse box any other fuses I should be checking? Thanks.
Old Dec 25, 2014 | 11:18 AM
johndoesdamage's Avatar
johndoesdamage
Run a code reader and tell us what codes you have
Old Dec 26, 2014 | 02:07 AM
nachospizza
I can only use a code reader from the shop!!! those OBDII reader here couldn't read any codes... but I use my Greddy Infrometer and it got one code but cannot shown what number thought!!! Wondering if I can still drive it to the shop without my fans working????
Old Dec 26, 2014 | 02:08 AM
nachospizza
How do I check if relays for my fans are OK???? And where are the relays except the one in front of the battery???
Old Dec 27, 2014 | 04:02 PM
sportbiketed's Avatar
sportbiketed
Umm your radiator fans have nothing to do with your climate control.
Old Dec 27, 2014 | 07:58 PM
nachospizza
Really so my radiator fans not working I am OK to drive??? I didn't turn on fan or the A/C I don't want to over heat my car. I thought the fans are for cooling down the engine????
Old Dec 28, 2014 | 03:41 PM
Conway_160's Avatar
Conway_160
So are you saying your engine fans aren't working or are you saying your climate control fan isnt working? If your engine is normal operating temps you should be able to turn on your a/c and one of your radiator fans should turn on.
Old Dec 29, 2014 | 03:52 AM
nachospizza
OK problem fixed fans are working just it won't turn on right after I switch on my car... because weather here recently is kind of cold. ALso CEL light up because some electrically wire got loose... cleared the code no more cel... I guess car getting old something loose when the road is bumpy...
Obadabot
Jun 18, 2023 11:31 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
