Stupid Base Model VLSD install question
Old Dec 26, 2014 | 12:10 PM
chintzelman's Avatar
chintzelman
Default Stupid Base Model VLSD install question
I have an 05 Base model and I recently purchased a VLSD (pumpkin and all). I know this has been covered, but I have a simple short question and I know I have read it in the past, but I can't find it now. I have googled it and searched on this forum but didn't see it.
I have the entire VLSD within its original pumpkin. Now I was under the impression that I can just unbolt my open diff and bolt in this new pumpkin with the VLSD inside. I thought I read that my open diff axles will be fine.
Was I correct that I can use my open diff axels with this VLSD pumpkin, or did I need to buy the VLSD axles?
Thanks and sorry again. I will do a write up when I am finished to hopefully prevent future questions.
Old Dec 26, 2014 | 12:16 PM
2bad240's Avatar
2bad240
Your axles will be fine.
Old Dec 26, 2014 | 01:55 PM
clubhopper's Avatar
clubhopper
Straight swap.
Old Dec 26, 2014 | 07:13 PM
terrasmak's Avatar
Axles fine. If you got a unit without stub axles you would not be able to use yours
Old Dec 27, 2014 | 11:50 AM
SQuaLZ's Avatar
SQuaLZ
As others said, straight swap. Although I highly recommend changing the bushings before the swap. I only did Whiteline inserts but I regret not changing them before installing.
Old Dec 28, 2014 | 10:39 AM
MURDAH350's Avatar
MURDAH350
^^ agreed with the other posters. what you are thinking of is swapping the internals in which case you do indeed have to buy new inner axle flanges. this also applies when upgrading a base model diff to a limited slip with aftermarket internals.
Old Dec 28, 2014 | 11:58 AM
chintzelman
Thanks guys. I'm swapping this diff in as a spare and winter diff. This should help me from becoming a one wheel wonder while in the snow. But a spare as I'm getting an OS Giken super lock LSD installed in my open diff.
Now to research diff fluid. I thought I read somewhere about diff fluid that works better than the OEM recommended stuff. To google!
Old Jan 8, 2015 | 12:13 PM
Painter6988's Avatar
Painter6988
where is every one finding these vlsd pumkins at? i cant find **** online or ebay, any help would be great in the market for one. i live in a small town so finding local junk yards with 350z parts are next to impossible. thanks
Old Jan 9, 2015 | 08:27 PM
WeightLimit's Avatar
WeightLimit
Wellllll you can start here: http://car-part.com
Old Jan 21, 2015 | 07:06 PM
B T's Avatar
B T
is the donor and your car both 6MT? I know the G35 had different final drive ratios between the transmissions
Old Jan 25, 2015 | 05:35 AM
SQuaLZ's Avatar
SQuaLZ
I used Redline for both my tranny and diff and no complaints here. Definitely felt the difference in my tranny, but could not really tell a difference in my diff considering I changed the fluid before I installed the new diff, so I really had no baseline to compare to. However, since it is so good in my tranny I swear by Redline now. Blows away OEM fluid.
It took me a very long time to find a local pumpkin. I easily found pumpkins online but all of the stub shafts were removed. Finally found a local that was selling one and jumped right on the deal. It was honestly my best mod, looking back I don't know how on Earth I drove this car with an open diff, especially in AutoX events.
The biggest difference for me is in bad weather. I have SO much more confidence driving in the rain and snow in this car.
aarrgghh
May 1, 2022 11:04 AM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
etong
Sep 10, 2015 06:14 PM
