3rd gear grinds at high rpms
Old 02-25-2015, 09:20 AM
CNunes_95
CNunes_95's Avatar
Default 3rd gear grinds at high rpms
Hey guys, I have my 03 Z Touring Edition. Car runs greats and shifts nice and smooth for the most part. However, I have one issue. My car grinds when I upshift to 3rd gear. If I drive it normally, it drives just fine. I've noticed that once I reach 4,000 rpms in 2nd gear and attempt to shift to 3rd, it grinds. When I revmatch to downshift into 3rd, it never grinds and shifts just fine too. Also, this only began happening once the cold weather really started to settle in. Do you guys think this is happening only because of the cold weather? Or will I need a transmission rebuild in the future due to syncro wear or something a long those lines?
Old 02-25-2015, 10:48 AM
travlee
Master
travlee's Avatar
Received 9,058 Likes on 6,522 Posts
try changing the fluid first
Old 02-25-2015, 10:53 AM
iideadeyeii
iideadeyeii's Avatar
syncro /end thread
Mine has been doing this for 3 years. I just jam it in
Old 02-25-2015, 11:02 AM
Syner
Syner's Avatar
Try the fluid first. Double-clutch until you find a CD-009 at a decent price?
Old 02-25-2015, 12:23 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,261 Likes on 2,319 Posts
What they all said. Except for the "jam it in" part. Hahahaha!
Known issue with some of the early 001 transmissions.
Syner mentions the CD-009.... that's the later version ('05+) where the 3rd gear issue was resolved using an extra cone synchro on third gear cog.
No need to rush out to swap your tranny if you're careful and finesse third up and down as you are doing.
FWIW, I swapped to Redline MT-85 GL4 two years ago in an effort to quell the issue. Didn't help me so I resorted to just changing my shifting style on this car. More double clutch, rev match, etc, all better for clutch and tranny anyhow.
Old 02-26-2015, 06:10 AM
iideadeyeii
sherm
04-11-2020 05:21 PM
11-01-2015 05:25 PM
EnjukuRacing
09-30-2015 06:55 AM
Conway_160
Drag
09-29-2015 08:07 AM
Quick Reply: 3rd gear grinds at high rpms
