How Lean when Coasting/Shifting
Old Mar 7, 2015 | 04:06 PM
Sunset350ZR's Avatar
Sunset350ZR
Default How Lean when Coasting/Shifting
I have headers, test pipes and catback. When I coast/shift etc. my a/f ratio will spike to 20 and instantly come down to 12-13 once I step on the gas. I have searched and a few post have said this is normal and not a problem. I am just checking to make sure that lean under these conditions especially a/f of 20 is ok.
Thanks for any help
Doc
Old Mar 7, 2015 | 04:42 PM
Conway_160's Avatar
Conway_160
Ummm well considering when you let out of the throttle you loose most of the fuel untill your rpms fall to idle.. it will peg the sensor untill your ideling again then will go back to ~14.7
Old Mar 8, 2015 | 09:00 AM
Sunset350ZR
So definitively its ok for car to spike like this as long as it returns back to 11.5 to 13.5 under load?
Old Mar 8, 2015 | 09:14 AM
terrasmak's Avatar
It will do that bone stock, same as all other cars
Old Mar 8, 2015 | 12:36 PM
mr. sparco's Avatar
mr. sparco
No load, goes to vacuum, less air, no need for fuel, no worries.
Old Mar 8, 2015 | 01:35 PM
Conway_160's Avatar
Conway_160
Well technically if hes N/A he will always be in vaccum.
Old Mar 8, 2015 | 01:52 PM
mr. sparco's Avatar
mr. sparco
Well at wot my vac gauge reads 0 so it's at equilibrium with the atmospheric pressure or 14.7 psi. So it's technically never a complete vacuum.
Old Mar 8, 2015 | 02:36 PM
str8dum1's Avatar
str8dum1
its called decel fuel cut.
Old Mar 8, 2015 | 10:33 PM
Sunset350ZR
Thanx
Old Mar 9, 2015 | 10:15 AM
iideadeyeii's Avatar
iideadeyeii
Yes it's normal. /lockthread
pdexta
Sep 14, 2015 11:27 AM
Chebosto
Aug 6, 2003 06:31 AM
Oh4aZ
Mar 28, 2003 12:35 AM
menehune
Feb 14, 2003 05:11 PM
