Recommended oils & Filters
Old Feb 8, 2004 | 07:00 PM
jesfuego's Avatar
jesfuego
Default Recommended oils & Filters
I thought this would be useful info. My buddy has a 04 Maxima and he send me this over from Maxima.org. Im not sure if this has been posted here yet, I did a search with no result.
Recommended oils and Filters
Dino and "Blend" oils:
Castrol GTX 5W/30
Mobil 1 Drive Clean 5W/30
Mobil 1 Drive Clean Plus 5W/30
Pennzoil PureBase 5W/30
ULX-110 5W/30
Drain Interval: Up to 5k
Synthetic oil:
Amsoil TSO Series 2000 0W/30 Synthetic
Mobil 1 SuperSyn 5W/30
Amsoil ASF 5W/30 Synthetic
Redline 5W/30
Drain interval: Up to 10k with oil filter change halfway through chosen interval (i.e. 8k drain interval -> 4k oil filter change)
NOTE: For hot climates (i.e. south), 10W/30 can be substituted and in colder climates (i.e. north), 0W/30 can be substituted.
Oils to stay away from IF going over 3,000 mile intervals:
Any Valvoline Oil (consistent sub-par analysis results, all tend to shear down real quickly; additive packages are inferior to other brands)
Castrol Syntec Blend Castrol Syntec Full Synthetic Oil [NOT GTX] (consistent so-so to sup-part analyses results and shady marketing practices)
Royal Purple Oil (too expensive considering there are other better synthetic oil choices)
NOTE: These oils will protect fine up to 3,000 miles, they just don't represent a good value based upon their additive package and/or their oil analysis reports for Maxima-specific engines. It does not mean they "suck".
Recommended Oil Filters for VQ engines, ranked in order of preference based upon my own observations:
Mobil 1 M1-105 (fits VQ35DE only)
Nissan OEM 15208-9E000 ONLY (for all VQ30DE and VQ35DE engines)
Mobil 1 M1-110 (fits both VQ engines, but bypass valve isn't as good as M1-105 filter)
Amsoil SDF-20 (fits both VQ engines)
Oil Filters to avoid:
Nissan OEM 15208-65F00 (specified for VQ35DE by Nissan dealer; refuse to purchase this filter as it has cardboard endcaps like low quality Fram filters; insist on the dealer using the 15208-9E000 oil filter as it has a better overall construction quality)
STP S6941 (Production change in mid-2003 to Mexico has created inferior quality; Some fitment issues on VQ35DE engines, so only VQ30DE engines should use this one)
Bosch 3323 (Production change in mid-2003 to Mexico has created inferior quality; for all VQ30DE and VQ35DE engines)
Any SuperTech filter (Due to production change in mid-2003 to Mexico that has resulted in inferior quality)
Any filter made by Fram (consistently poor construction quality)
Amsoil SDF-13 (pricier than SDF-20 and smaller)
Mobil 1 M1-108 (pricier than M1-110 and smaller)
Old Feb 9, 2004 | 11:16 AM
rufus3000's Avatar
rufus3000
Default Re: Recommended oils & Filters
"Royal Purple Oil (too expensive considering there are other better synthetic oil choices)"
I would have to disagree with your buddy on this. The only oil I feel is even in the same ball park is the amsoil. And the price is about the same depending on where you buy it.
Old May 23, 2004 | 07:47 AM
IsatteliteI's Avatar
IsatteliteI
what does your buddy reccomend for manual transmission oil?
Old May 23, 2004 | 11:30 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
For easy of purchase and widespread availbilty, you cant beat Mobil 1 synth. I use 5-30 in my engine, and 75-90 synth in my tranny and differential. Safe, easy, and very effective. Why overcomplicate it? )
Old May 24, 2004 | 07:05 AM
jun14scr's Avatar
jun14scr
i agree. royal purple oil is pretty well priced. u can get a case, 12 quarts, for 55 dollars. you do the math. i think last time i checked, shipping was free also.
Old May 24, 2004 | 06:37 PM
Enron Exec's Avatar
Enron Exec
What id like to know is where can we get the Mobil 1 M1-105/110 oil filters for cheaper then 11.95 at Autozone? Id buy a case if i had to.
Old May 24, 2004 | 06:55 PM
NY 350Z's Avatar
NY 350Z
gq_626 - did you put GL-4 in your tranny? i used 75-90 mobil 1 in my rear diff (gl-5).
i thought it only came in gl-5
Old May 24, 2004 | 10:18 PM
knowleqe's Avatar
knowleqe
have you guys tried Torco or Neo ?
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
