throttle position relearn
Old Mar 14, 2015 | 08:20 AM
Bamdon16000's Avatar
Bamdon16000
Default throttle position relearn
I have a 2005 manual Trans 350z. Just wondering what the throttle relearn was. Tried googling it but kept getting altimas. Replaced the throttle body unit and now it revs around 1500 rpms for idle. If I give it gas it revs to 2500 but keeps revving 500 rpms after I full release the gas
Old Mar 14, 2015 | 09:51 AM
WTFMike's Avatar
WTFMike
I posted the link in your other thread...
Old Mar 14, 2015 | 01:57 PM
Bigsyke's Avatar
Bigsyke
Curious on why people need to do the relearns? I have simply unplugged my battery for a few hours and everything was fine.
Does it need a little extra calibration or something after the ECU is reset?
Old Mar 14, 2015 | 04:11 PM
terrasmak's Avatar
Mine runs much better with a relearn after the battery has been removed
Old Mar 14, 2015 | 06:35 PM
Bigsyke's Avatar
Bigsyke
Hmmm. That's good to know. I have never had idle or throttle release problems after letting the car sit without a battery for 8 months or so.
I have also done the resets a few times with no change, but that's not to say something didn't change. Maybe it's running factory specs initially, and doing the throttle resets calibrates it to the current conditions [throttle body being dirty, pcv valve volume, etc].
Old Mar 15, 2015 | 06:03 AM
92K1500's Avatar
92K1500
Will the relearn not work with an uprev tune installed? I've tried multiple times using a clock to time it and I finally gave up. I can't get the CEL to come on or blink.
Old Mar 15, 2015 | 08:00 AM
terrasmak's Avatar
It works with the tune, well it does on my car.
Old Mar 15, 2015 | 08:07 AM
92K1500's Avatar
92K1500
I must be doing it wrong then. I've tried it about 7 times total on 2 different days with no luck. She runs fine so it's probably a waste of time anyways but I wanted to try it since I had the TB off for cleaning.
Old Mar 19, 2015 | 12:02 PM
str8dum1's Avatar
str8dum1
you coolant has to be at least 70*C for any relearn to take place.
Very specific instructions are given in the FSM for it to happen. Gettin the foot pedal timing right to trigger the relearn means you need to be able to read a stop watch. Cant help with that.
Dr.Paulyy
Jul 29, 2019 07:45 AM
Depravity
Oct 1, 2015 04:49 PM
Darkspy
Sep 7, 2015 09:09 PM
