clutch pedal bleeding issue?
Old Mar 20, 2015 | 10:22 AM
D.R0905's Avatar
D.R0905
Default clutch pedal bleeding issue?
Hey guys, I purchased a master clutch from z speed, installed it and now I'm trying to get pressure in the pedal. I've been at it for almost 2 hours, and still nothing. There's no leaks, everything is tight. Anything you guys can think of?
Old Mar 20, 2015 | 10:40 AM
jdm-v35's Avatar
jdm-v35
Do you have an RJM pedal bracket? if so that would happen. also, are you bleeding it correctly? open slave bleeder, depress pedal, tighten bleeder, then bring pedal up and repeat.
Old Mar 20, 2015 | 10:46 AM
D.R0905's Avatar
D.R0905
I have the oem pedal bracket. I only changed the master clutch, the hose that came with it, I attached it to the one that attached to the transmission, I pressed down on the pedal about 5 times opened up the bleeder and pumped again for about 12 times then I just kept pumping after that but nothing.
Old Mar 20, 2015 | 03:01 PM
jdm-v35's Avatar
jdm-v35
thats the issue. youre probably doing it wrong, or at least not the best way. At least in my experience, best way is to have someone help you, give the pedal a couple pumps then hold it to the floor. have someone open up the bleeder while pedal is depressed, then close it once pressure is released. pull pedal back up, couple pumps, release pressure then tighten bleeder. repeat till done. I did a full 6mt swap so I put new everything, and it was fully bled in about 15 min.
if you added the SS hose from the master(like i did) you may need to give it about 10-15 initial pumps to get the fluid to flow up the hose. It doesn't like fighting gravity at the start. user your hand to pump, its faster and easier as the pedal will keep sticking to the floor. but should be normally bled how I said after that.
Old Mar 20, 2015 | 03:13 PM
bcsigs's Avatar
bcsigs
**disclaimer This is not the only way or the exact right way to do this, just the method I used when I had a similar problem bleeding the clutch on my 03 touring after replacing a blown clutch line**
If you lose all fluid in the master cylinder you have to reverse bleed the clutch, because the master cylinder will not return to the open position and thus the clutch pedal just flops to the floor, I had the same problem when I blew a clutch line and went to bleed the clutch, put fluid in the clutch reservoir, open the bleeder screw on the slave cylinder and get a piece of fuel line preferably 3-4 ft long and put it over the bleed and secure it with a hose clamp, then fill the fuel line with brake fluid and and blow it into the slave cylinder either by mouth or with an air compressor (I used a compressor, brake fluid is likely the most foul tasting automotive fluid) and blow until all fluid in line has filled slave and reached master cylinder and you see bubbles forming in reservoir, then tighten bleeder remove hose and you should be able to bleed the clutch normally
Old Mar 21, 2015 | 07:04 AM
D.R0905's Avatar
D.R0905
Your method helped me a lot!I bled out from the master first instead of just opening up he valve and closing it as I saw on a diy. And my other problem was that I had to adjust the rod with the fork. As soon as I did all that I bled the system in about 15 min. Thank y'all so much for the help! Another thing, is the pedal suppose to be soft? It returns all the way up by itself. But it feels soft I guess. I replaced my clutch a while back with s messed up master cylinder and it felt a little different.
lapham3
Oct 7, 2022 03:15 PM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
