Dampening the 2500rpm death vibration
Regards, MicVelo: One of the more expensive possibilities. Been there, done that. Got the tattoo.
Forum member Aussie983 posted this a couple of years ago:
"I had this problem, and figured the only thing capable of vibrating so bad would be a failing dual-mass flywheel. I replaced my OEM flywheel, and this vibration when decelerating went away. It was not a driveshaft issue.
I hope this helps others out there looking for the source of the problem.
The other source of random vibration that is not related to deceleration, and if you find you've definitely had your wheels balanced, is to check your compression rod/radius rod bushings. That was the other source of my random vibrations that weren't related to the drivetrain."
Bigsyke, if vibration is felt in the shifter at 2900 and 4100 RPM, especially when downshifting following a loading of the drivetrain by acceleration and then goes immediately away when clutched there's a strong possibility your DMF is worn.
Since when has trolling been tolerated on this forum? Nitpicking the type of transmission mount?
There are clearly some other deep-rooted issues going on here. You've done the same thing in other threads. Most of your responses have been void of any substance. Please do not bloat this thread with garbage any further.
