Timing cover caps gasket replacement
Old Apr 6, 2015 | 07:35 AM
Super_Mario's Avatar
Super_Mario
Default Timing cover caps gasket replacement
So I yesterday I noticed one of my timing cover caps was leaking oil, so I did a little research and decided to change the gasket. I read that I had to use rtv or gasket maker so that's what I used. I first took off the 3 bolts, I believe they were 10mm then I slowly started to fit a VERY thin flathead between the cap and the timing cover and starter to pry it open. It was a little annoying because it you have to be very careful not to damage the groves on the timing cover. Then I cleaned both surfaces really good and put gasket maker and both surfaces, let it get tacky then put the 3 bolts back in. Seems to be holding up perfectly😃
Old Apr 6, 2015 | 07:56 AM
rustyschopshop's Avatar
rustyschopshop
Yup just a little rtv on these bad boys is all thats needed. I used ultra gray on mine.
Chris350z03
Oct 8, 2023 07:19 PM
allmycarsdie
May 13, 2016 04:38 PM
seagrasser
Oct 11, 2015 03:27 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
