Help Clutch Replacement (Underway)
Old Apr 11, 2015 | 11:10 PM
92_BigD's Avatar
92_BigD
Default Help Clutch Replacement (Underway)
Hello all I have a 06 350z base with about 48k on it I have had it for two years. And finally burnt my clutch up with past owners wear and tare. I couldn't change it for a few months so lets just say I ordered a new kit I got a Southbend Clutch / Flywheel Combo
https://conceptzperformance.com/Cart...n.php?II=12350 <<< The Kit.
So My grandpa and my step dad took on the task of not taking it to the shop and doing it our self's what a task it was. I am no mechanic but the other two are so it does help that I had them. So we got the transmission on the ground currently as of today 4/11.
So here is my Question The new flywheel has the pin notch the one to line up the flywheel with the crank censor I believe Like I said I am no mechanic. But this New one comes with Two pin Notches One says Front and the other says Rear. Also the notches have a T55 bolt width between them
NSK1000-SS-O Southbend Stage 3 Clutch Disc
SBCNIS-2 Southbend Aluminum Flywheel
I have Googled/forums for this for about 2 hours before I even considered posting
Old Apr 12, 2015 | 09:08 AM
92_BigD's Avatar
92_BigD
So no one has A good Idea of what it could be?
Old Apr 14, 2015 | 08:52 AM
92_BigD's Avatar
92_BigD
So here is the Update ON the kit I got. The notches to match up the timing with the flywheel The Front means FWD and the Rear means RWD. I feel really dumb cause now its seems rather obvious. We are so close to being done Will post pic after the replacement is done
07ZEKE
Aug 23, 2021 09:15 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
