What is this hose
Old May 17, 2015 | 01:16 PM
callia6's Avatar
callia6
Default What is this hose
What is this hose and is it okay for me to just unclamp it and remove it from the radiator?
Old May 17, 2015 | 01:19 PM
92K1500's Avatar
92K1500
Which one? There are about 5 hoses in that picture?
If you're talking about the large diameter hose with the clamp loosened, that is your upper radiator hose.
If you pull it loose you'll spill coolant everywhere unless you drained it already.
You will also have to bleed to cooling system so your heater will work again.
Old May 17, 2015 | 02:39 PM
travlee's Avatar
travlee
Master
wow, just wow.
Old May 17, 2015 | 06:39 PM
nizmo_0385's Avatar
nizmo_0385
Wow indeed. I get why most flame noobs but this is pretty bad.
Old May 18, 2015 | 05:31 AM
StuLax18's Avatar
StuLax18
General & Tech Moderator
Your radiator clamp is loose as well. I would assume you knew this, but considering the original question I want to make sure.
Old May 18, 2015 | 05:46 AM
travlee's Avatar
travlee
Master
that hose is not needed, you can remove it
Old May 19, 2015 | 11:11 AM
sportbiketed's Avatar
sportbiketed
Makes sure that you properly warm up the car before removing the hose.
Old May 19, 2015 | 03:43 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
Old May 19, 2015 | 10:16 PM
callia6's Avatar
callia6
Yeah I need to remove the hose with clamp loosened my bad I didn't look closely at the pic to see if there were anymore hoses. But how can I safely remove this hose from my radiator, like I pulled it and coolant came out, can I just drain it all that way and it be fine after? And just refill it after I put it back
Old May 20, 2015 | 03:43 AM
jdm-v35's Avatar
jdm-v35
you should not need to refill it. it's just the top hose and not much will come out. Just put it back on and you should be good.
Old May 20, 2015 | 04:13 AM
Conway_160's Avatar
Conway_160
Why are you removing it?
Old May 20, 2015 | 05:31 AM
iideadeyeii's Avatar
iideadeyeii
this
Old May 20, 2015 | 05:33 AM
jhc's Avatar
jhc
Epic
Old May 21, 2015 | 11:42 AM
callia6's Avatar
callia6
I'm trying to take off the radiator so I can replace the lh side radiator support
Old May 21, 2015 | 12:21 PM
sportbiketed
Sounds like you do not know what you're doing, bleeding all the air out of your system is going to be a real birch.
Old May 21, 2015 | 12:52 PM
Syner's Avatar
Syner
Old May 21, 2015 | 12:57 PM
callia6's Avatar
callia6
I already have everything ready to be switched out, this hose is the only thing holding the radiator to the car. And if I have to bleed something can you let me know so I can ask for assistance on that. I bled my brakes before, so what do I have to do for this.
Old May 21, 2015 | 01:01 PM
Syner's Avatar
Syner
I just realized you're the guy that the tree hit... lololol
Old May 21, 2015 | 01:03 PM
sportbiketed
Originally Posted by Syner
^this
Old May 21, 2015 | 01:08 PM
dkmura's Avatar
dkmura
General & DIY Moderator
OK- let's start from the beginning. What are you trying to do here? The upper radiator hose is also paired with the lower radiator hose, and if you already pulled THAT, than you mist have already drained the radiator, right? After you get through with reinstalling everything, you will need to properly refiill the radiator so you don't trap air and cause overheating.
