Car grounding
Old Jun 17, 2015 | 08:03 AM
pr_350z's Avatar
pr_350z
Default Car grounding
Can someone post all the 350z grounds? my ECU fried and I only found one ground loose(which i dont know where it goes), I want to make sure all grounds are connected before installing new ECU. Thanks in advance
Old Jun 17, 2015 | 08:52 AM
str8dum1's Avatar
str8dum1
there are only 2 harness grounds in the engine bay. both attach to the timing cover.
Old Jun 17, 2015 | 12:09 PM
pr_350z's Avatar
pr_350z
well actually under the plastic engine cover i found one, then behind the windshield washer fluid reservoir there is another one, then there is another one close to the intake(all of this grounds come from the harness, because there are multiple others that go from the engine to the chassis of the car), still searching online and on my car where all other if any grounds are. but thanks for the reply!
Old Jun 17, 2015 | 12:43 PM
pr_350z's Avatar
pr_350z
Dont know if this might help other people searching for the same thing, but found that in the FSM the PG section from page 26 to 37 states every ground in the car and where they go to.
aarrgghh
May 1, 2022 11:04 AM
m_0g
Jun 3, 2021 10:05 AM
OdesiTT
Sep 30, 2015 10:47 AM
cashmoney03
Sep 27, 2015 05:24 PM
