Arc v2 catch can uninstal help
Old Jun 25, 2015 | 02:31 AM
mpackhamreed's Avatar
mpackhamreed
Default Arc v2 catch can uninstal help
I am not overly mechanically minded and need some help disconnecting my ARC V2 oil catch can. Is there anyone on here who can give me an idiots guide/photos ideally of how I need to restore my oem DE z once I disconnect my ARC.
Any guidance would be hugely appreciated.
Thanks
Martin
Old Jun 25, 2015 | 06:30 AM
graffkid732's Avatar
graffkid732
Post pics of bay, will be much easier. Also, looking to sell it? haha.
Old Jun 26, 2015 | 02:36 AM
mpackhamreed
Default Photos for assistance
Thanks. Photo link attached of my current set up and the two oem hoses I have found. Please help !!..
Old Jun 26, 2015 | 04:11 AM
Conway_160's Avatar
Conway_160
Why are you wanting to disconnect it?
Old Jun 26, 2015 | 04:35 AM
mpackhamreed
Default Can
Returning to the OEM set up as I have changed my bay now and it doesn't look right. I just want to know how to reinstate it back to how it was...
Thanks
Old Jun 26, 2015 | 12:45 PM
guitman32's Avatar
guitman32
Refer to FSM sections "Intake Manifold Collector" and "Rocker Cover Removal And Installation" for the diagrams of the stock PCV system.
Old Jun 26, 2015 | 04:32 PM
guitman32's Avatar
guitman32
Google:
Old Jun 26, 2015 | 09:22 PM
mpackhamreed
Thanks.Thats helpful.Can you confirm the front hose runs from where the short hose from my arc can currently runs to and then back to the front of the plenum and the rear hose in the drawing diagram runs from where my left long arc hose runs too at the back of my plenum to the air intake tube ?. The front right hose on the arc currently runs to the intake tube so is removed and not replaced?..
Thanks so much for your help
Old Jun 27, 2015 | 04:02 AM
guitman32's Avatar
guitman32
Forget about the ARC install, just make sure you copy what you see in the pic...have the crossover hose connecting the two valve covers in front, the hose from the PCV valve on the pass side valve cover goes to the lower plenum port, and the port on the drivers side aft goes to the intake tube. Done.
DSport G35
Dec 4, 2007 06:50 PM
G Thizzle
Nov 25, 2007 11:11 AM
