clutch fluid leaking
Old Oct 7, 2015 | 08:38 PM
shane310's Avatar
shane310
Default clutch fluid leaking
any one have an idea or the first spot I should check when clutch fluid is leaking ?
I have an after mark slave cylinder installed about year and half ago , and now when I drive or not drive the clutch pedal will stay on the ground and not come up if I push the pedal in and hold it down it cause the fluid to leak and I don't know where yet I fill it up and it takes about 30 sec of holding the pedal down for the fluid to show below the low mark where you fill the clutch fluid up,
if it leaks from the master , where would I look ?
if it's the slave, do I need to pull the tranny off ? (witch would suck lol)
Old Oct 7, 2015 | 08:48 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Look at the bottom of the clutch master itself to see if the plastic base is cracked (unlikely) or the rubber line itself is split. If there's no apparent leaks around the clutch master itself, the next place would be to check all the clutch lines leading down to the bellhousing. Depending on whether you have a DE or HR, you can check the slave cylinder next. If there's leakage from the front base of the bellhousing, the only choice is to pull the tranny.
Old Oct 7, 2015 | 09:24 PM
shane310's Avatar
shane310
it's hr 08 base model
Old Oct 8, 2015 | 07:05 AM
dkmura's Avatar
dkmura
Since you have an HR, check the area directly underneath the front of the bellhousing. If you find brake fluid leaking from the flange onto the garage floor, you'll know it's the CSC and will have to pull the tranny.
Old Oct 8, 2015 | 07:16 AM
travlee's Avatar
travlee
Master
he prob isnt leaking, the slave prob took a dump on him. replace with the zspeed setup and never look back
Old Oct 12, 2015 | 07:27 PM
shane310's Avatar
shane310
oh it's leaking for sure iv filled it about 5 times now so the fluid has to be going some where , it dose drive fine tho and shifts with no problems , just if you hold the clutch in to long your have to refill it so now I carry a bottle of brake fluid with me lol
dose zspeed carry a all metal slave , I got mine from gtm witch was all metal , iv looked on line and seen after mark ones but the are plastic base so I don't know lol
Old Oct 13, 2015 | 03:27 AM
travlee's Avatar
travlee
Master
yes they do, and holy hell your grammar sucks
Old Oct 13, 2015 | 05:31 PM
shane310's Avatar
shane310
sorry you don't like my grammar lol , I don't really care about grammar on forums , but you did get my point so I did do something right haha , all good !!!
tommyz9
Northern California
21
Jan 17, 2016 07:00 PM
Wyv
Oct 24, 2015 07:56 AM
Justin100
Oct 7, 2015 06:01 AM
dblue30
Oct 6, 2015 09:28 AM
EnjukuRacing
Drivetrain
Oct 2, 2015 06:57 AM
