Anything else I should change with engine out and upper oil pan removed?
Old Apr 7, 2016 | 05:00 AM
jdm-v35's Avatar
jdm-v35
Default Anything else I should change with engine out and upper oil pan removed?
So eventually(hopefully before end of this summer) I am planning to pull the engine out of my G and Paint the engine bay. I also am getting another front and rear timing cover powdercoated to replace the current color front timing cover I have on. I am going to probably start the wire tuck this weekend in preparation.
I have all the seals for the front/rear timing cover, will change engine mounts and I have a small rear main seal leak, So I would like to change it while in that far. Are there any other parts I should change while I have that off?
Car has 65k, was procharged, now just ztube/popcharger, exhaust, lightweight clutch/flywheel. Maybe will go FI again in the future but it would be a while if so.
Old Apr 8, 2016 | 01:20 PM
rcdash's Avatar
rcdash
Weld in a fitting for oil drain above oil level! When you put in a low mount turbo with oil scavenge pump, you will have the hard part done!
Old Apr 13, 2016 | 10:18 AM
jdm-v35's Avatar
jdm-v35
didnt see the reply. lol thanks for the info! maybe I should try and get that one while im in there. can't hurt!
I may consider doing other things while in there. Just not clear on bearing sizing except that once its open there is a letter code to determine the size..
Jarrod VanSell
Dec 1, 2022 02:14 AM
allmycarsdie
Apr 26, 2021 06:38 PM
Bilazaurus
Apr 2, 2016 07:02 PM
B_hoss
Brakes
Mar 16, 2016 10:50 AM
350zchad
Mar 10, 2016 04:29 PM
