Replace/Fix Broken hood bolt?
Old Mar 8, 2016 | 01:49 PM
350zchad's Avatar
350zchad
Default Replace/Fix Broken hood bolt?
Any ideas on how to repair/replace hood bolt? I snapped the damn thing tightening a new nut?
Its one of the 4 studs that go through the hinge
Old Mar 8, 2016 | 03:00 PM
travlee's Avatar
travlee
Master
that is the one that is fixed in the hood right?
Old Mar 8, 2016 | 03:10 PM
350zchad's Avatar
350zchad
yes.. going to a body shop I guess.. to have them weld a new one on.. sucks these aren't easily replaceable
Old Mar 9, 2016 | 05:25 AM
350zchad's Avatar
350zchad
so the shop is going to grind it weld another bolt paint to cover grinding and done... $200
Old Mar 9, 2016 | 03:47 PM
KJFire4Life's Avatar
KJFire4Life
YIKES!!! $200 for a 10 minute job and a spray can of paint........I mean it's not horrendous if you don't have access to a welder. But yeesh! I feel for you man, seriously do. Better luck next time I hope
Old Mar 9, 2016 | 03:57 PM
350zchad's Avatar
350zchad
if i had welding skills, I would attempt.. but the car is pristine and want it done right... bad enough my Heman muscles broke the bolt.. besides they will make the paint look better than I could.. just glad it's not visible from the outside.
Old Mar 9, 2016 | 04:08 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Welding skills are mandatory- use too much heat and damage to the paint and surface contours will cost way more than $200. Although I don't know how you weld a steel stud to a aluminum surface...
Old Mar 9, 2016 | 04:12 PM
travlee's Avatar
travlee
Master
Old Mar 9, 2016 | 04:57 PM
350zchad's Avatar
350zchad
good point.. from a quick search its common for body shops to have TIG welders (for aluminum welding).. Ill double check with them tomorrow, this is why I'm having the pros do it.
Old Mar 9, 2016 | 07:14 PM
KJFire4Life
There's an attachment for stud welding. Essentially a big conducting claw. Hit the trigger it pushes one pulse, bam studs welded. Doesn't mar, doesn't push electricity or heat through the entire structure. Very simple and easy to use, just have to make sure it's set right. So yes, no welding skills will require a shop and professional to do it. Good points everyone
Old Mar 9, 2016 | 07:21 PM
350zchad's Avatar
350zchad
On a side note z spec ultimate engine bolt dress up kit is the real deal and looks great!
Just don't muscle tighten too much
Old Mar 10, 2016 | 01:15 PM
350zchad's Avatar
350zchad
update...
I was able to put the old nut back on and tighten enough to hold the hood down.. not having any work done now.. hope it lasts
Old Mar 10, 2016 | 02:04 PM
travlee's Avatar
travlee
Master
you should be good as long as you don't take it on or off a lot
Old Mar 10, 2016 | 02:42 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
You could get a carbon fiber hood, mine just has a threaded section and you use a bolt to attach the hood.
Old Mar 10, 2016 | 04:29 PM
350zchad's Avatar
350zchad
not a fan of cf hoods
tjc6591
Apr 29, 2026 01:22 PM
Coz@CZP
Feb 9, 2018 04:38 PM
N80
Mar 2, 2016 04:05 AM
Ace2347
Feb 15, 2016 08:46 AM
Akkidonz
Feb 10, 2016 07:13 AM
