Another limp mode please send help
Old May 13, 2016 | 06:19 PM
Tanahara's Avatar
Tanahara
Default Another limp mode please send help
Changed spark plugs via taking plenum off all hodes and connectors are on and good. Not a single code but at 2.5k rpm i hit a rev limit which i think is the limp mode plus not so hot idle. Anything you guys can offer as guidance would be great
Old May 13, 2016 | 06:24 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Something isnt plugged in... Quadruple check everything you did...
Old May 13, 2016 | 06:26 PM
Tanahara's Avatar
Tanahara
I have i have repeated the steps 3 times to just triple check everything
Old May 13, 2016 | 06:31 PM
Tanahara's Avatar
Tanahara
Only thing i have not done is put the 2 brqckets That hold the wire around the plunum but unless that grounds the wire harness it shouldnt matter
Old May 13, 2016 | 08:23 PM
Tanahara's Avatar
Tanahara
So the issue was in the greedy emanage the throttle needed to be remeasured since i unplugged it when removing the plenum.
Old May 14, 2016 | 11:32 AM
seymore4's Avatar
seymore4
Professional
Sure would have been helpful to know you had one of those in there when trying to troubleshoot...
Old May 14, 2016 | 02:46 PM
i8acobra's Avatar
i8acobra
Yeah... Never turn the key on for any reason with the throttle body unplugged.
Old May 15, 2016 | 07:05 PM
Tanahara's Avatar
Tanahara
I was testing for leaky injectors, but does the emanage throttle calibration replace the throttle relearn on the stock ecu or do i also need to do the relearn?
Spaz85
Apr 3, 2024 08:34 PM
Nabice
Aug 19, 2016 08:13 AM
Tanahara
May 11, 2016 09:00 PM
Sleeper_Z
Apr 28, 2016 09:21 PM
