Revs not dropping causing me to grind gears when shifting fast!
Old Jun 26, 2016 | 06:23 PM
James Cook's Avatar
James Cook
Question Revs not dropping causing me to grind gears when shifting fast!
Hello this is my first post so if i'm in the wrong place ill move this thread but I recently bought a 2004 350z 6spd and got a new transmission in it (planned expense) but now when i'm attempting to shift quickly I notice my revs dont drop immediately! so i'll take you through the motions :
1. You hit the gas
2. You push your clutch all the way in and yank that bad boi into second
3. Your grind your gear even tho you had the pedal all the way down
I can see my revs not dropping right away and can basically grind gears whenever I feel like it just by shifting fast, I went and watched other nissan 350z 0-60s and watch their revs drop right away sooo whats my issue?
thanks, James
Old Jun 26, 2016 | 06:49 PM
Deteria's Avatar
Deteria
Synchros prolly going out. Get a lighter flywheel so revs drop quicker?
Old Jun 26, 2016 | 08:16 PM
James Cook's Avatar
James Cook
Its not an issue of the revs dropping quicker its that the clutch doesn't disengage right away it seems, because after a second the revs will drop normally
Old Jun 26, 2016 | 09:28 PM
dcains's Avatar
dcains
Sounds like you've watched too many F&F movies.
Old Jun 27, 2016 | 04:38 AM
travlee's Avatar
travlee
Master
maybe learn how to drive... dunno
Old Jun 28, 2016 | 08:13 AM
rcdash's Avatar
rcdash
It could be that the clutch is not fully disengaging? Have you tried evaluating for this and/or adjusting?
Old Jun 28, 2016 | 08:33 AM
iideadeyeii's Avatar
iideadeyeii
Tranny is bad or clutch isn't fully disengaging.
Old Jun 28, 2016 | 09:02 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
^^^ This.
Betting on a hydraulic issue. Try re-bleeding the system.
Old Jun 28, 2016 | 09:26 AM
terrasmak's Avatar
I think I figured it out
1. Hit throttle
2. Release throttle and push in clutch at the same time
3. Shift gears
4. Release clutch and back on throttle
terrasmak's Avatar
1. Hit throttle
3. Shift gears
Old Jun 28, 2016 | 09:50 AM
turboed350z's Avatar
turboed350z
Its cause youre granny shifting and not double clutching like you should be.
Old Jun 28, 2016 | 09:52 AM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
dboyzalter
You beat me to the punch
Old Jun 28, 2016 | 10:05 AM
turboed350z
By 2 whole min lol
Exphiliac
May 2, 2016 01:18 PM
Rev_Night
Drivetrain
Apr 18, 2016 07:53 PM
graygear33
Apr 18, 2016 12:34 PM
Gothicash
Apr 17, 2016 04:10 AM
grr01gsr
Apr 12, 2016 03:18 AM
