Tomei LSD Help!!!
Old Jun 29, 2016 | 11:16 PM
Onyx z33's Avatar
Onyx z33
Default Tomei LSD Help!!!
Hey what is up guys!! New here, now I been doing tons of information before I go with this install but no exact answers to what I'm looking for. Hopefully someone can help me out here. What additional parts will I need to install the tomei trax LSD 2 way. Its going into a 05 Base Z. Any info would help out!
Old Jun 29, 2016 | 11:30 PM
terrasmak's Avatar
Ring gear bolts , and maybe stub shafts depending on what your prior diff is. I typically just drop the 3rd member off at Dans Driveline , they rock
Old Jun 29, 2016 | 11:34 PM
Onyx z33's Avatar
Onyx z33
Awesome thanks man!! It'll be directly replacing a open diff...I got info from z1motorsports but all they told me were all I will need is just shims but I don't wanna believe it'll be that simple since I heard there would be additional parts needed. Thanks again
Old Jun 30, 2016 | 07:42 AM
terrasmak's Avatar
Yes, it needs to be shimmed, Dans has everything to do it. You can probably get away without changing ring gear bolts but ..... Then carrier bearings, you can remove the old ones from the diff or just replace them, I like the idea of replacement.
Old Jun 30, 2016 | 07:44 AM
HRMoneyPit's Avatar
HRMoneyPit
How much do they charge?
Old Jun 30, 2016 | 07:54 AM
terrasmak's Avatar
It was $175 to swap the carrier
$225 for a full setup, like if your changing gear ratios.
Plus parts, I've had my old ranger rebuilt there, and Z when I swapped the diff, Z when I swapped the gears. Also brought many customer diffs to them.
Just about every car that is raced at LVMS has had their drivetrain work done at Dans Driveline
Old Jun 30, 2016 | 01:40 PM
Onyx z33's Avatar
Onyx z33
Is it $235 if I hand them the core or $235 total if I bring them the whole car?? And who would you recommend there to get the job done? Thanks again in advance.
Old Jun 30, 2016 | 05:56 PM
HRMoneyPit's Avatar
HRMoneyPit
I want a Quaife but the 2300 Z1 wants is a ton. I understand the rebuild with OEM parts and all, and shipping is expensive but damn
Old Jun 30, 2016 | 09:14 PM
terrasmak's Avatar
$175 if you hand them just the core , if your not doing a gear ratio swap. $225 if you are swapping gears.
To make everything easy, I keep an extra diff at my house. Build my spare, swap it in the car, I keep the old one. My rates are also really good, pm me if your interested
rsxscrazy
Feb 14, 2009 11:29 AM
asianflip06
Dec 4, 2006 10:55 AM
Wired 24/7
Aug 6, 2006 10:55 AM
Gruppe-S
Jul 24, 2005 02:16 AM
Poizon
Nov 9, 2004 04:47 AM
